RB25DET ENGINE BUILD PART OUT
Please note, engine was assembled and never left the engine stand before parting out. None of these parts have been run. Machine work was carried out by James Race Engines/Engine Action Flemington and can provide receipts for work.
ALL PRICES ARE SOMEWHAT NEGOTIABLE
Block
-New welch plugs
-Head surface decked square to bores
-Bores light honed(Still 86mm)
-Tomei oil restrictors installed in rear two head oil feeds
-Includes crank girdle/bolts, oil quirters, sump pan, oil pickup, AC/PS/engine mount brackets & rear main housing with brand new Rear main seal
$400
Head
-Hardness and crack tested
-Head face surfaced
-Brand new supertech bronze valve guides, Genuine nissan exhaust manifold studs, Camshaft seals & valve stem seals.
-Includes standard cams, valves, valve springs, hydraulic lifters, cam gears and VCT solenoid
$1000
Crankshaft
-Crack tested
-Grubscrew cleaned
-Checked for straightness and polished
-Wide oil pump drive collar fitted
-Includes crankshaft timing gear & crankshaft bolt
$400
Genuine Nissan Timing belt with brand new idler & tensioner pulleys(Including spring)
$150
HKS RB adjustable exhaust cam gear
$100
RB25DET intake manifold/Plenum/fuel rail
Has brand new genuine Nissan gaskets for AAC valve, throttle body, Plenum>runners and runners>head
$80
RB25DET standard used pistons & rods with new ARP rod studs
$100
Genuine Nissan RB 86mm rings(No gapping was neccessary, they are as they came from the factory)
$150
Genuine Nissan RB head bolt set
$50
RB 20/25 Flat cam covers and VCT timing cover set. Finished in wrinkle black, incudes Brand new Genuine Nissan cam cover seals and aftermarket half moon seals
$250
Nismo engine mounts for RB25DET
$150
https://www.sau.com.au/forums/topic/437153-vic-rb25det-build-part-out/
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
