No holds and no shotguns, nothing is sold till it's paid for or a deposit is put down.
I can ship anything anywhere if you pay for it. Pickup is available no probs.
RB-Z gearbox
RB bellhousing with Z32 rear housing (RB and Z32 gearsets are the same)
- bolts onto an RB-series motor, RB20, RB25, RB26, RB30
- comes with Z32 shifter setup (not pictured)
- great for RB-motor conversions
- if you have an rb30/26 for sale then let me know I might buy it from you and use this gearbox behind it.
Price: $950
Blitz I-color Spec R twin solenoid sequential boost controller with 3/4 optional extras
*** all up it's a boost controller with gear or speed sensitive boost, boost gauge, water temp gauge, oil temp gauge, oil pressure gauge, multichannel logging system and performance meter ***
- best boost controller hands down
- twin solenoid for stable boost control
- all in one monitoring system so you don't need 6 gauges across your dash
- includes the optional Blitz oil temp sensor, plug and play
- includes the optional Blitz oil pressure sensor, plug and play
- includes the optional Blitz auxiliary-in wiring harness, plug and play
- I set it up to monitor water temperature as well
- can also monitor stuff like throttle position, AFM voltage, injector usage etc
- includes a set of s15 sun visors where I've mounted the display
Price = $750
Blitz triple sensor set sold.
Blitz I-color SPEC-R boost controller still available, price = $500
Price drop = $460
Auto Service MATSUFUJI s14 clutch pedal brace, may fit s15 and s13 but I don't know for sure.
This braces the clutch pedal bracket and stops it from flexing; is a good mod for those that run tuff clutches or likes to kick it once in a while. Stops the flex and stops the pedal bracket from breaking.
BRAND NEW
Price: $80
Price drop: $60
Price drop: $50
Price drop: $40
Brand new genuine Turbosmart 4" straight silicon
Price: $20
Custom s15/s14 catback exhaust with varex oval twin tip / stealth
Bee-R racing mid pipe with custom axle back and varex oval muff.
Hardwired the flap to a switch but I still have (I think) the wireless remote - you can have both. The flap gets stuck sometimes. Some scraps and bangs here and there. What you see is what you get.
Price: $380
GTR32 front brakes
- includes pair of calipers. one caliper is missing a bleeder but Vsport gave me another one that seems to fit well - this is the big daddy 32mm thick version - thickest setup from Nissan, rarest of the alloy 4 pots. Was rebuilt and painted black before I installed it.
- includes pair of rotors - 296x32mm - freshly machined
- includes pair of pads - randoms
- includes hardlines
- inlcudes custom Goodridge ADR approved braided brake lines from my s15, probably suits s14 and s13 and 180sx, maybe R32 / R33 / R34 as well?
Price: $400
Steering wheels
Works bell 350mm original, left in image, good condition, used = $100
Genuine VERTEX 325mm, brand new never used, DISCONTINUED model, rare --- right in image, BRAND NEW WHEEL used horn button = $450
Deep dish vertex not for sale.
s15 ignition key light
this is from the JDM s15 model, aussie delivered models don't have this light ring around the ignition barrel. includes a blue light.
Price: $50
Here's an IDEA of what it looks like (it's a random google pic)
s15 tail light wiring looms.
i have two pairs of looms, from ADM s15s that I was going to rewire to JDM spec so the whole brake lights up.
both pairs = $50
one pair = $30
this is what it looks like to have the whole brake light lit:
Carbonetic / ATS ACROSS full 100% carbonfibre single clutch kit with flywheel and throw out bearing + carrier.
The only reason I'm selling this is because it started slipping over 320wkw, otherwise it's the best clutch hands down - i've used alot of different clutches before this including organic, single, twin, puck, sprung, unsprung etc.
I bought this single plate kit for $1800 and because it was soooooooooo good I'm now using a the same Carbonetic / ATS ACROSS carbon fibre clutch kit, but now I'm twinplate.
The carbon disc looks in good condition but since it slipped I would recommend you machine the flywheel and pressure plate.
The carbon disc brand new measures 4mm, it now measures 3.6mm which is 0.4mm of use - see below for pics.
Suits 5-speed gearbox SR20's, such as s14, s13, s15 5spd, r33 gearbox conversions, z32 gearbox conversions.
Price: $700
http://imageshack.us/a/img844/5864/l27g.jpg
Here is the pic of the carbon disc when new - new is 4mm, this is currently at 3.6mm which is 0.4mm of usage:
http://img843.imageshack.us/img843/1387/ziay.jpg
s15 center console / arm rest pocket
This little pocket has mounts specifically for s15 console/arm rest. there's 3 positions you can put it into. great for holding little things or coins instead of rummaging through your whole arm rest pocket.
Price: $40
http://imageshack.us/a/img834/5492/k5i6.jpg
http://imageshack.us/a/img842/4808/frg1.jpg
http://imageshack.us/a/img854/8415/u93n.jpg
Other info:
Cant get through via pm
Any chance of more pics of the works bell steering wheel?
adamadz2332@hotmail. Com
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
