Hey guys,
I have some stuff in my garage that I would like to get rid of.
All items are located in Georges Hall, 2199, Sydney.
PM or call 0402 564 237
Item 1: Rays/Nismo LM GT 1 18 x 10 + 20, white centre with polished
Price: $2490
Condition: Lips have been polished up and look great. Centre’s are not too bad, id say a light polish and they would come up good as new. I’m getting rid of these because I have a set of Bronze TE37’s coming and just don’t have the room to keep 3 sets of wheels!
These are a 1996 build so I’d say one of the first set to be made. Look pretty damn good for a 18 year old wheel!
6F3EE3BE-0D98-4ED5-AB7C-0D8C8E6E8439_zps
50E0CF3A-20D1-4852-B4F3-9F223EB8AC92_zps
A60CBEB4-031F-44F4-8C70-747D2EA58438_zps
Item 2: Cobra Suzuka Pro seat
Price: $750
Condition: Brand new. I bought it 2.5 years ago and by the time I went to put it in the car, I don’t fit in it anymore. I’m simply just going to by the next size up. Would have less than 3 minutes total sitting time.
69783A5A-9426-4176-A7CB-502F2BDC7519_zps
DB78E217-AD82-4FB8-BEDF-CA00A4D13D6B_zps
Item 3: Racepace 9.5 Litre 4WD sump.
Price: $1450
Condition: It’s an unused ‘modified’ sump. You send Racepace yours, they modify it and send it back. It has been sitting in my garage wrapped up for 18 months.
A58FD253-D84C-40CA-8756-E2955C4894DF_zps
F2CD3C1D-104D-4CEC-8526-73A02EEC8EF6_zps
19169D1E-8B26-4F74-94CF-4E8291840239_zps
Item 4: R33 GTR sliding seat rail
Price: $100
Condition: It came out of “JAGR33’s” car from Melbourne and never put it in mine. Can’t see what could go wrong with a seat rail but I have not had it in my car to try it out.
3D4F7CE9-EA8C-4199-AF4B-5CA9843332EA_zps
Item 5: Tomei forged RB26/RB28 pistons. 86.5mm in size. NON VALVE RELIEF!
Price $200
Condition: These came out of my last engine when it let go. Hardly any wear marks on the skirts although they have a slight tap on the tops where the exhaust valves hit the piston when I smashed my oil pump. I would have reused them but I was going to use high lift cams and wasn’t sure if I was going to go down the VCAM route.
7C3502EF-09B6-467A-92A5-922A67660C46_zps
10C38384-C01D-4A22-A7AD-C0EFA666FF44_zps
Item 6: Tomei 270 @ 10.25 mm procams
Price: $30
Condition: These, as above, came out of my last engine. The lobes are fine but there is some scuff marks where the caps hold the cam down. They might be able to be cleaned up. Nice cam for someone that wants some decent top end.
08A93354-F842-4991-B016-0E31ACF39EE4_zps
A48A43FD-92BA-40F7-B72E-4D34A8BAE4D1_zps
B6BAD908-AC18-49BB-A89E-5FB3916D3680_zps
Item 7: RB26 Ignitor
Price: $70
Condition: Worked in my engine but due to an upgrade I did to the ignition system, it’s no longer needed.
10461EAF-E8F5-4A12-82FA-65C313AEFCD3_zps
Item 8: HKB quick release.
Price: $100
Condition. Once again, came out of JAG R33’s car and I never fitted it. It was working on his car before he pulled it off.
94696D4F-64F4-47C0-A2EA-A9B5DC7264BD_zps
251428F0-703D-4014-9475-2616AFA6DCFA_zps
Item 9: R33 GTR V Spec front diff centre
Price: $30
Condition: Was working fine, I just upgraded to a Quaife centre.
D9CEF13D-CB63-473B-817B-7798B2E01F00-178
Item 10: Ikeya Formula Tension Rod, Pillow ball type
Price: $200
Condition: In my car for 15,000 kms or there abouts. I only removed them as my roll centre adjuster kit comes with this particular arm. No noises from the pillow ball at all. These are high quality.
7BB042F8-BC77-44F3-A1EF-8E6092E8D6B8_zps
Item 11: R33/R34 Nismo Type R suspension 12kg/mm front 10kg/mm rear.
Price: $2,000
Condition: No leaks or bangs. The front’s were refurbished in 2011 by a company that Aaron at Import monster uses. Only changed due to doing a whole custom suspension setup.
*I only have 3 struts ATM due to the guy that did my custom setup using the 4th strut for a few reference point’s. I will get that back very soon.
** These are basically a Ohlins Flag R, just painted Nismo colours. Last time I looked, the Flag R’s were 650,000 yen ($6,000 or so).
  • Like 1
https://www.sau.com.au/forums/topic/437158-piglets-gtfo-of-my-garage-sale/
Some more items I found today
Item 1: RB 26 head
Price: $50 or a case of beer
Condition: This came out of my last engine. It has some damage on the cam journals, missing 2 or 3 caps, every exhaust valve is bent but intake valves are fine. It has been ported and it made 426 RWKW at 24 psi using -5's. Maybe a few caps and a tunnel bore with some new valves would make it usable, I don't know. If it doesn't sell, i'll turn it into a coffee table.
84FDA636-F8DD-4FF3-BB76-0E4DE1F53E86_zps
63682CBB-646D-4B89-8249-924A0AEAB9DE_zps
B9B04BEE-A24A-4294-8185-AB122ED17424_zps
A61BC014-1ED9-443A-958C-CECAD2FF49B3_zps
10335BE2-F3BC-4E19-BE14-338AE166133C_zps
CC400575-C7CC-4A4A-A282-CA77B41373E6_zps
A8D57741-F7F1-49BA-93F1-32FB867823DF_zps
Item 2: Sparco quick release
Price: $45
Condition: Brand new. I just wont use it.
3689B797-5A18-4F6F-8927-1FAA7615505F_zps
Item 3: Tomei Type A springs and retainers
Price: $150
Condition: Fine. Came out of the head above. I'm not 100% sure on the retainers, possibly factory. These were in the head for 35,000 kms.
B3D0396B-589A-4289-A804-B84D923FD8D5_zps
570459C6-B14D-407A-A7A8-D356D53AC7C4_zps
Item 4: OEM RB26 coil packs
Price: $100
Condition: I think we ran into issues around 400-410 rwkw mark. I believe IIRC we changed the ignitor at the same time. These were on the car for no more than 7,000 kms.
