Hey Peeps
Thought I would do a write up as it seems there isn't one anywhere else and the 350Z or G35/V35 isn't the same..........
these colour codes were taken from a double din radio - non bose type.
12V Constant - Yellow/Pink.
12V Switched (Ignition) - Light Green/Pink.
Ground - Red/Blue.
Head Light Signal / Dimmer - Green/White.
Front Left Speaker: White & Black. (do not know polarity)
Front Right Speaker: Red & Green. (do not know polarity)
Rear Left Speaker: Yellow & Brown. (do not know polarity)
Rear Right Speaker: Pink & Blue. (do not know polarity)
There were 5 colours left over but I did not bother finding out what they were.
Cheers, Theo.
Very nice work. How did your replacement stereo fit in the slot? I did mine on the weekend, and I'm not 100% satisfied with the fit, but was in a rush at the time. Now ceebs taking everything apart again.
If you're lazy (like me) and can't solder for shit, I bought this ISO and it works well.
http://www.ebay.com.au/itm/Nissan-1995-stereo-ISO-WIRING-HARNESS-plug-connector-/260669742342?pt=AU_Car_Parts_Accessories&hash=item3cb1209d06&_uhb=1
it didn't sit in that flush either but cant do much about it with the counter sunk screw's.
I don't have a problem with soldering (I'm an electrician by trade) I'd rather know its right and have a good joint, not like these auto electricians who twist it together and tape it LOL
here's a photo.......
  • 3 weeks later...
Hey guys just to add to this, when I wired my speakers to an amp, the wires with a trace are negative and the solid coloured wire twisted with it is the positive one.Cheers
is this not common knowledge.
I'm just adding info to the post josh, as Theo noted in the first part that he did not know the polarity. So I guess you could say it's not common knowledge, or he's not a commoner, or he was taking the piss and I fell right into it.
In electronics line generally means positive.
^ The Focals I wired in use clear speaker cable and the one with red trace (line) is used as positive, which is opposite to the standard wiring setup so yeah...like Brick said. Every manufacturer makes their own rules
Scott can you paste a picture of all the head unit wires???
the Green/White wire and also the Red/Blue wire would be a start though.
need to figure out why my interior lights, parkers and tail lights aren't working........ I've replaced the BCM and still nothing :(
See if any of this helps. It seems the pages after the ones I've printed are predominately about the navi operation & repair.
AVpt1.pdf
AVpt2.pdf
What I normally do is find what I think I need in the English G35 version & then try to find the equivalent section in the Japanese M35 manual (translating where necessary). If there happens to be any changes to wiring terminals/colours etc, you may be able to catch it before cutting the wrong wire.
AV_lowres.pdf
Good luck & let me know if you need more.
Cheers, Leon.
DONT NOT GROUND THE RED/BLUE WIRE!!!! it is actually the cabin lights/parkers/tail lights!!!
I think I've blown the BCM by doing so!!! FFS
don't worry, fuse you need is third on left row in the vertical fuse box near the battery, you have to remove the plastic shield in the bottom of the glass to access it!
it is called "tail ***", if i'm wrong on placement. surely you will find the reason in this box :yes:
Edited by Erop
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
