Hey Peeps
Thought I would do a write up as it seems there isn't one anywhere else and the 350Z or G35/V35 isn't the same..........
these colour codes were taken from a double din radio - non bose type.
12V Constant - Yellow/Pink.
12V Switched (Ignition) - Light Green/Pink.
Ground - Red/Blue.
Head Light Signal / Dimmer - Green/White.
Front Left Speaker: White & Black. (do not know polarity)
Front Right Speaker: Red & Green. (do not know polarity)
Rear Left Speaker: Yellow & Brown. (do not know polarity)
Rear Right Speaker: Pink & Blue. (do not know polarity)
There were 5 colours left over but I did not bother finding out what they were.
Cheers, Theo.
Very nice work. How did your replacement stereo fit in the slot? I did mine on the weekend, and I'm not 100% satisfied with the fit, but was in a rush at the time. Now ceebs taking everything apart again.
If you're lazy (like me) and can't solder for shit, I bought this ISO and it works well.
http://www.ebay.com.au/itm/Nissan-1995-stereo-ISO-WIRING-HARNESS-plug-connector-/260669742342?pt=AU_Car_Parts_Accessories&hash=item3cb1209d06&_uhb=1
it didn't sit in that flush either but cant do much about it with the counter sunk screw's.
I don't have a problem with soldering (I'm an electrician by trade) I'd rather know its right and have a good joint, not like these auto electricians who twist it together and tape it LOL
here's a photo.......
  • 3 weeks later...
Hey guys just to add to this, when I wired my speakers to an amp, the wires with a trace are negative and the solid coloured wire twisted with it is the positive one.Cheers
is this not common knowledge.
I'm just adding info to the post josh, as Theo noted in the first part that he did not know the polarity. So I guess you could say it's not common knowledge, or he's not a commoner, or he was taking the piss and I fell right into it.
In electronics line generally means positive.
^ The Focals I wired in use clear speaker cable and the one with red trace (line) is used as positive, which is opposite to the standard wiring setup so yeah...like Brick said. Every manufacturer makes their own rules
Scott can you paste a picture of all the head unit wires???
the Green/White wire and also the Red/Blue wire would be a start though.
need to figure out why my interior lights, parkers and tail lights aren't working........ I've replaced the BCM and still nothing :(
See if any of this helps. It seems the pages after the ones I've printed are predominately about the navi operation & repair.
AVpt1.pdf
AVpt2.pdf
What I normally do is find what I think I need in the English G35 version & then try to find the equivalent section in the Japanese M35 manual (translating where necessary). If there happens to be any changes to wiring terminals/colours etc, you may be able to catch it before cutting the wrong wire.
AV_lowres.pdf
Good luck & let me know if you need more.
Cheers, Leon.
DONT NOT GROUND THE RED/BLUE WIRE!!!! it is actually the cabin lights/parkers/tail lights!!!
I think I've blown the BCM by doing so!!! FFS
don't worry, fuse you need is third on left row in the vertical fuse box near the battery, you have to remove the plastic shield in the bottom of the glass to access it!
it is called "tail ***", if i'm wrong on placement. surely you will find the reason in this box :yes:
Edited by Erop
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
