Ok i needed to get a RWC the other day. before this my car randomly cold in the morning in second gear when driving out of first obviously it would skip. or missfire randomly feel jumpy. ok and the other day i washed and degreased my engine bay got some water under the coil packs cover. started the car up and it was missfireing. so i took everything off and blew out the coilpack area for like 20 minutes making sure everything was dry. it stopped the missfires. but then the next day. all the time no matter what driving through 1st 2nd and 3rd i get random skips feels like its missfiring between 1000 to 3000 after 3000 it clears right up and is smooth as but accelerating from 1000 -3000 is skippy and missfiring.
anyoen think its my spark plugs?? or coil packs??
ive also seen maybe O2 sensor but how do i check that. i know its in the Cat but how do you test it if its ok. or should i just go to like auto tune and get someone to plug in to my car.
i dont know how to test it, would be good to know if you can, they are cheap though....
but also if your car's a 33 the o2 sensor is in the dump pipe, the one youre talking about is the sensor to tell you if the cat is screwed...
sorry i cant be more help...
Tried cleaning the AFM?
Sensor in the cat is the temp probe so ignore that. As stated, the O2 sensor is on the dump pipe.
Also a good idea to change spark plugs if you haven't done so recently. BCPR6ES-8 is what you want. Don't bother spending more on the expensive ones.
Have you looked at changing the coil packs if they haven't been changed recently?
Skyline coilpacks are a SHHHHHHHHHHH of a thing. Change them out for yellow jackets if you are poor, spitfires if you have the $$. If its factory coils then you got a good run out of them on an R33. R34 ones usually only last 100,000km tops before one starts to go poo.
yea my 33 has done 211k but ive heard a coilpack when gone missfires at higher RPm not low ones.
this weekend ill replace my spark plugs and clean my AFM see if that helps. thanks everyone.
if the O2 sensor is gone. wouldnt a check engine light come on though thats why i dont think my O2 is screwd think it should be fine.
Found out in my midnight rush to dry out the coil pack area i practically snapped 2 very old brittle vacuume lines. popped the bonnet yesterday went to start pulling everything off to do spark plugs. got 2 vacuum lines of looked at them and 2 big splits on either end of each hose replaced them both with ordinary air line from my work(diesel mechanic) replaced my spark plugs whiulst i was at it. they wernt to bad but thaught might aswell least i know there done and when was done.
no missfires since :D still needs turbo though hahaha
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
