so I pulled the plugs and they were all good. figured I would do a comp test while they were out.
cylinders 1-5 were around 110psi.
cylinder 6 was around 45...
I think I have found the problem, just a coincidence out occurred the day I put the pump in :(
oh fuark, now that sucks big time!
.. hmmm that could have been through a lean out also, you did say you were only getting some whacked voltage to your fuel pump.
Did a pressure test and leak down test. Looks like it's the rings. Well I was about to switch to e85, looks like ill build the motor first I guess
R34 motor too.. they're supposed to be build as tough as volvos
  • 4 weeks later...
Just an update on what eventuated.
Ended up being the lack of power supply to the pump caused the spark plugs to cook themselves.
Visually they were fine, but after chucking in a new set to double check, problem solved.
The low comp is an issue to sort out in the near future, but in the mean time made 330 RWKW on E85.
Will strip the motor and rebuild once the lack of compression becomes more of a problem.
Cheers for all the help everyone.
If it was just the rings, you could potentially rebuild it quite cheaply. Just a hone and new rings if the pistons haven't been smashed. I'd be checking the ring lands then just throw it back together
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
