Hey guys,
Ive been doing some reading and I've heard all sorts of things people have done to get rid of the hicas system on rb26's when swapped into a car that doesnt have hicas. A couple of ideas floating around are replacing crank and p/s pump with a rb25 crank n pump, something about turning the hicas part into a power steering cooler?, and last, taking apart the pump and removing all the hicas internals and then closing and sealing it up, but i heard this can cause your pump to grenade..so dont want to go down that route.
I would rather keep using the 26 pump and mod it to where the hicas part is for a power steering cooler, but if no one knows what im talking about with that then i guess i could get a 25 crank n pump. :/
Any ideas or past experiences would be greatly appreicated ! thanks alot guys!
Yeah, you can just pass the outflow from the rear half of the pump through a PS cooler, or just a length of pipe even, and straight back to the return.
If it were an RB20 it's trivial to just swap to R33 pump, but of course that's not so easy on a 26.
If you have hicas aready fitted, kits such as the whiteline locking bar include a bypass tube to fit into the rear which just circlates the fluid.
On our R32 GTR i pulled out the hicas rack, fitted a whiteline one, didnt use the bypass pipe included with the locking bar, removed the hoses etc and bypassed the fluid to run through the factory cooler.
Now my 2 Hicas steel fluid lines can be used as fuel return lines for the fuel system im setting up. :)
ill post a picture of my pump so i can have a better understanding of what your saying but basically theres the two bolts on top of the pump that i would use regardless, and then theres the y pipe outlet that is used for the hicas from my understanding? and your saying to take off the y pipe and loop them together with no outlet?
car doesnt have hicas from factory.
Removing the vanes from the rear pump stage is easy and will work fine. Mine has been running that way for 8 years.
so you removed the vains and capped off the hicas port?
No. Not quite. The pipe on the side (whether it is a Y pipe or not - there's two sorts available) is the inlet. That is the fluid from the reservior. The outlets are on the top. See this thread for a nice picture of the system. http://www.skylinesaustralia.com/forums/topic/372154-rb25-into-r32-using-rb25-non-hicas-pump-help/
Both outlets go forward and down to a mounting next to the radiator support. Then rearwards to the crossmember. Then across the crossmember. The front outlet reports to the steering rack (I think via the cooling loop) and the rear outlet reports to the HICAS solenoid on the driver's chassis rail. I think. You could/should follow the lines yourself to make sure.
Edited by GTSBoy
i checked out the link. I get what your saying about the Y pipe being the inlet from the reservior, and the two at the top are outlets for the rack. now when you started talking about the rear outlets report to the Hicas solenoid on drivers chassis rail, i dont think i have one of those since car doesnt have hicas from factory (240sx s14). I can go snap a picture of my steering rack if that helps?
Yeah, well, that's fine. The rear outlet on the pump is definitely the rear steer outlet. The front definitely goes to the rack. So whatever modification you do (looping the rear stage outlet back to the reservoir, looping it back via a cooler or removing the vanes from inside and plugging the outlet) you just plumb from the front outlet to your rack.
so i basically gutted the pump and then put it all back together without the gears. is that what everyone does?
Hopefully Duncan can let you know whether you should remove the whole lot, or just the little vanes out of the rotor.
Either way, you need to leave the front stage alone.
This. Works fine.
Or just use a R33 GT-R pump, they don't have a rear feed and the pump itself it actually about half the size and weighs a little less as a result. Good for tight engine bays/conversions if you're close to engine mounts or similar
This. Works fine.
I think its pretty hard to get hands on a r33 gtr pump in states, but ill look into finding one. thanks alot
the vanes are just the little shims inside the gear?
LOL good job, you have now removed the rotors and vanes out of the front and rear chambers of the power steering pump. Now your power steering won't work at all.
For starters there are no "hicas gears" in the p/s pump. All you had to do was remove the rear cover off the p/s pump, remove the vanes from the rear rotor (not even touching the front section of the pump), bolt it back together and cap the rear outlet off so no dust can get in there. The little pieces of metal that go into the rotor are the vanes. What the red arrows are pointing to in the picture.
Also the vanes are shaped like this, if they are installed the wrong way they will chew the shit out of the housing. Make sure you install them the right way when you reinstall the rotor and vanes back into the front chamber.
....well atleast it only took like 10 mins lol .time to put back together haha. thanks for clearing that up man
Yep exactly what sick_r31 said. Just remove the vanes from the rear stage only, put everything back together, and cap the rear outlet with an appropriate size bolt and copper washer.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
