Hey guys I have my Vipec plugin up for sale. it came out of my 32 GTR and was tuned and installed by Insight Motorsports.
I have had the board tested by Scott at Insight and it's in perfect condition.
I will get more details and photos when I pick the board up from Insight, but as far as I'm aware it is the model in between the V44 and V88 for GTR's. I will find out what other cars are compatible. Comes with box and ECU case.
$1300
https://www.sau.com.au/forums/topic/437210-fs-vipec-plugin-for-gtr/
Got some photos. Scotty confirmed it's a V44 with extra injector cables to suit 6 cylinders. Suitable for R32, R33 & R34 Skylines all models (except for R34 GTT).
The impul case is just the standard ecu case but with an impul badge as it previously had an impul ecu.
https://www.dropbox.com/s/cg7200f7g74oeij/20140107_132404.jpg
https://www.dropbox.com/s/fqvl7n7fj7omcn3/20140107_132355.jpg
Hey mate,
interested in the vipec.
Does this have the boost control feature?
What is the main difference between this one and a new model?
Could you PM a price express posted to WA 6019.
I have money ready, so give me a fair price and i'll pull the trigger asap.
PM sent too.
Michael
just to clarify.
this is a original vipec plug and play board for SKYLINE RB.
It supports all RB's including R34 GTR via dip switches, so rb20 rb25 rb26, EXCEPT IT DOES NOT SUPPORT R34 GTT NEO.
It has does not require any extra harness's for supporting a 6 cyl, it does that standard, those extra cables there is the expansion cable which allows you to connect extra aux devices / temp sensors ($50 add on or something)
it has full boost control, you just connect it to where the original one was in the first place.
it has a inbuilt map sensor also, its a true plug in solution for RB skyline.
this ecu is HIGHLY capable when in the hands of a tuner that knows what they are doing with them, can work well with 150kw to 1000kw + setups.
hope this helps.
  • Like 1
PM sent :)
just to clarify.
hope this helps.
and thanks for the info Guilt toy
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
