Hi All,
I am new to this forum and would greatly appreciate any help.
The Story...
About 3 weeks ago I bought an R34 GTT 2 door... finally... car seemed in good nick, I have done bout 1500km's since and is my daily driver.
Mods:
POD filter
cat back exhaust.
(As purchased)
Now the issue I started having was the engine light, TCS, and slip lights intermittently coming on, they would come on and go away on restart. Sometimes I wouldn't see them for days. After a search around the forums I put it down to coil packs as the car would have a very slight miss occasionally when the lights where on but apart from that it ran fine minus a little power. Now to the issue at hand, a couple of days go I went to the shops and spent about half an hour there, once I came back to the car it didn't want to start. It would crank about 3 times as usual but it was like it just barely wouldn't start if that makes sense. It would almost fire but just not enough. I let it sit for about 20 mins after cranking it a few times and hey presto... started like normal(the engine,TCS and slip lights stayed on for the drive but car seemed to drive normally). Got home and turned it off and started it again within a minute or two and no problems 3 cranks and off she went no engine light nothing. let it sit fir an hour or so and again no problem starting and no lights on the dash, so I went for a drive for about 45 mins or so and stopped to get some food, again car started no problem. This morning on a cold start as per normal no issues, drove half way to work and stopped to get a coffee(normal routine) came out and again car won't fire. So I let it sit for about 20 minutes and it started like normal...hmmmm... drove to work(engine,TCS and slip lights on) car drove fine. Went into work and opened up, came back out and started the car (no more than 2 minutes since the car was turned off) no problems. so at lunch I started the car again and let it idle for about ten minutes again no issues. Turned the car off and about 2 minutes after tried to start it and it didn't want to start again.... car now stuck at work :(
I'm a noob to R34's so any help would be appreciated. The car is in Kensington VIC if anyone can help it would be great because I don't have a car at the moment and unfortunately I do need a car.
Thanks in advance to anyone that helps.
Pete
https://www.sau.com.au/forums/topic/437213-please-help-r34-issue/
Hi that was the first port if call i checked the main battery wiring and earths , all looks good as an uodate the car decided to start and run for a bit today then died and started again for a bit and died again. When it runs it runs perfectly as in I can put a cup of coffee on the motor and wouldnt spill a drop (smooth). Luckely I managed through a friend of a friend to have it scanned today while it was running and it came up with low voltage, ignition and cas faults. I have a new battery for it comming tomorrow as the current battery doesnt want to charge. Will see if that changes anything.
In the mean time if anyone would have a cas sensor to suit the rb25det neo that I could borrow to see if that fixes the issue before buying one I would realy appreciate it as my funds are low at the moment and I need to get the car going asap.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
