I've had this happen a couple times over the past 6 months; including some strange immobilizer activity.<br /><br />The first time I had the "AT" (auto trans) light come on and I noticed that the car stuck itself in 3rd gear or higher; it seemed to lock out 1st and 2nd.<br /><br />I tested it with the sequential, but the car wouldn't go into first or second gear.<br /><br />So I turned the car off and on again to try to clear it in case it was a computer fault, and the alarm/immobiliser went off. And I couldn't stop it. Had to manually disconnect alarm and battery and reconnect before the car would start.<br /><br />Haven't had the alarm thing happen since but the AT light/locking out 1st/2nd has happened once since.<br /><br />Any ideas? :/<br /><br />Not sure if its related but the engine seems to "stick" a a bit at 1500 rpm when cruising; I increase throttle and boost increases but revs stick at 1500 before suddenly jumping to 2000. Seems to have a slight vibration when this happens too.<br /><br />I'm thinking it might be trans related but not sure
The revs 'sticking' is due to the torque converter locking, and is completely normal.
The trans staying in 3rd is is limp mode, means you have a problem
in adelaide mv automatics is the only man to see.
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
