Most of the issue is like most forums, they go dead because the masses made the leap over to facebook for all the trolling and bullshit.
Forums to most are a thing of the past.
Personally I love forums because of the useful information you have access to, but whats the point in forums nowadays when you can
jump on fb and ask the same question that's been asked a million times and get given an answer without actually searching for it.
^^ I agree. And the biggest issue with SAU forums is that EVERY reasonable question to be asked, has been asked and answered. As a library resource SAU is unbeatable, but as for day to day organising cruises/meets etc, then FB is far more useful and has considerably more reach.
The BIG problem with cruises, is that the person that organises the cruise is responsible for ALL the activities that happen on that cruise - even by randoms. The cops have come down very hard on cruises, hence why you rarely see them anymore.
^^^ that's true, although being part of the R31 club in recent years, they have continued to keep up a yearly cruise which has gone off without a hitch...
with everyone transitioning over to facebook all the baggage that used to jump in on cruises seems to have declined...
I think organising a cruise a few weeks to a month in advance on the forums would net a reasonable result. and personally I think smaller groups 10 - 20or so cars is a good number for cruises...
I myself would organise a cruise but I don't get out enough to know many good driving roads, aswell as being a fairly new member/poster around here, but definitely behind the SA Cruise movement I'm 100% behind it. C'mon SA Boys get on it!!!
cruses are a massive thing at the mkment, my FB is full of cruses constantly.
even if we had a meet up and chit chat somewhere nice and even just a short cruise to somewhere else nice on a sunday, nothing hugely fancy
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
