  • 3 weeks later...
To Ash and the promise of meat :-)
to MS crew, any idea of what other dates are options with Sandown 16th Aug TBC, reason asking, just confirming non of the options would fall on the SAU kart Rnd#2 weekend b4 I sign up to it.
Was good to get to my first SAU track day (other than the nats years ago) & see what it's all about. Had a great day. Looking forward to the 16th at sandown! Thanks ash for the steaks & skewers.
I'm OS for two weeks in August. Going to miss next round at Sandown, but i'm not really sure what going on there in any case? Was PI a round? and what about that 3 track challenge thingy?
Can't say I was really happy with the PI WRX day, wet weather, then an hour of touring and passenger laps, then lunch, then porsche on its roof, meant I got a total of 11 full laps, 1.5 laps at any actual speed. The itch certainly didn't get scratched :(
We entering Sandown 16th August - email mentioned 20 places left, though site shows 95?
http://www.wrx.com.au/event-899288
It was mentioned, apparently it's only WRX club at this stage - I'll get onto the MS guys about advertising it
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
