Dave, you ripped AU3 !!!
haha thanks to the weather!
Yeh the 17th. But the day before is the Sandown round, so maybe not.
There is another PIARC in sept on the 20somethingth.
Unless dates have changed since I last added them to my calendar
PIARC Sprints @ PI
Sep 27/28
Nov 8/9
Tampered @ Winton
Aug 31
Sep 27/28
Nov 4
Dec 21
WRX had a round listed on Bathurst Sunday but fat f**king chance of going to that one.
PIARC Sprints @ PI
Sep 27/28
Nov 8/9
Tampered @ Winton
Aug 31
Sep 27/28
Nov 4
Dec 21
http://www.piarc.com.au/?page=calendar
PIARC Sprint with Superkart and VicV8s Races.16/08/2014 - 17/08/2014
Collins mentioned making PI an official round since everyone was there but I haven't heard from him about it so haven't bothered to update the spreadsheet.
I think I've only got the R3 update, worth releasing update to spice up Sandown entry or just refresh post?
Nah there wasn't an update as I never got confirmation as it being a round.
That said an update would take 5 mins...
Has anyone got any type of confirmation for the 30th? Have never done a tampered day before but seen nothing by email yet.
LOL Matt. Can you even get to benalla on a tank hehe. Depending on who else comes, we'll see how many jerrys we can borrow and stuff in the boot of the prius.
Oh and Spreadsheet updated post Sandown round 5:
http://www.sauvic.com.au/motorsport/2014_ClubChampionship.xlsx
It might be a stretch - but I reckon I'll make it... :)
RE: bringing stuff in the boot - good stuff. Saves having to make two trips back to town.
Hey Simon - it's not so much a matter of not having jerry cans, more so space to fit them in the car :)
I'm not coming to this Winton, so have 2 x 20L jerry's you can borrow if ya want.
Can't you just turn up at a Tampered day and pay when you get there?
That only works if they have low entry numbers.
Unfortunately there's no way of knowing how many have entered other than calling them, which I just did, but apparently thew lady who organises the Tampered days is away today. Might try again tomorrow.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
