Thanks for these
was thinking of PIARC but off to SAU Karts.
There is also PI with AROCA but I'm out of town as I scheduled a Thai holiday to be back for cancelled WRX event
Tampered, will consider this as it's just been raised, even if Winton was the last event
Maybe I need inspiration and use this time to plan something different, drive try Tasmania, Sydney MSP, Bathurst Regularity etc
CircuitClub are out at Winton on 13th July.
Hey Peter what sort of turn out do they get? Good bunch of people?
I went back to Winton earlier this month after our SAU round and got down to a 1:42.6 from the previous 1:44 so I'm super keen to go improve on that again!
hmmm.. circuit club.
Do I need a fire extinguisher?
No, however you may carry one if you wish. There are fire extinguishers located at various points on the racetrack and the location will be made aware to you during the drivers briefing.
Is there scrutineering?
No. However you need to ensure that your car is safe and in good working condition.
And if the driver doesn't check their car?? :unsure: I'm sure they are a good group of enthusiasts, but these two points raised an eyebrow.
You guys aren't serious are you? Not like they're checking brakes or for oil leaks?
Scruinteering usually consists of brake light check, boot empty, helmet sticker, fire ext date and battery is clamped in. If you get some OCD type, they'll ask where your valve caps are....
I'll give the day a shot (at my own peril of course) if I can find the time.
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
