  • Replies 222
Good afternoon all.
looking to buy (or rent) some stock good condition gear to get a 32 gtr over the pits in SA
Stock struts
stock exhaust
stock airboxes
stock headlights
rear wiper
hicas system to replace lock bar
i will update if i need any other gear.
pm me on here, im usually online
After a set of R34 GTT stockies, pref with tyres.
Also after R33 S2 Silver boot (with or without stock spoiler) in good knick.
Also after R33 S2 (not sure if different from S1) rear bumper in silver also in good knick.
And if anyone is stripping an R33 S2 interior please let me know as I'm after several pieces.
PM'ing me on here is fine. Cheers.
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
WTB
Rb25 blown box. In particular I'm after the rear casing as mines cracked so would also just buy the casing if someone has stripped a box.
Also after a straight passenger side 32 front guard. Must have no indicator hole
Cash waiting. PM me or text 0431308647
Cheers
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
