Hey guys I am selling my 1998 Mitsubishi Evo 5 as I have found a car I really want, not only that I now have a work car I use for the week days. Once in a life time opportunity situation.
Engine: 4,500km
Odometer reading: 99,400km
Rego till DEC 2014
Price: $32,000 Negotiable
Contact number (Charles): 0424 519 217
If you are after a seriously fast and reliable Evo, look no further. The best thing about this Evo compared to every other Evo on the market is definitely the Haltech Flex Fuel Sensor and tune. Any of the following fuels can be used: 98ron, 95ron, E85. The Haltech flex fuel sensor can calculate the Ethanol content of the fuel or even the mix of fuel used and the tune is self adjusting. This Evo handles on rails with its Ohlins coilovers and swaybars. It really is the whole package. Price is NEGOTIABLE. NO TEST PILOTS.
Power package:
  • 2.3L stroker kit
  • Manley 100mm Billet knife edged crankshaft
  • Wiseco 1400HD 9.0cr pistons
  • Howards Ultimate Duty I beam conrods with upgraded rod bolts
  • AMS balance shaft delete kit
  • CNC ported valve throats
  • H11 Headstuds
  • Supertech 1mm oversized black nitride exhaust valves
  • Supertech 1mm oversized black nitride intake valves
  • Supertech Dual valve springs and titanium retainers
  • Supertech valve stem seals
  • Greddy Adjustable cam gears
  • Kelford 280 degree camshafts
  • Custom alloy airbox
  • Custom 4” intake
  • 4” K&N pod filter
  • Custom oil breather catch can setup with speedflow fittings and Teflon braided lines
  • Kiggly HLA
  • New OEM Mitsubishi oil pump
  • New OEM Mitsubishi water pump
  • New OEM Mitsubishi long motor gasket kit
  • ACL race bearings
  • PWR alloy radiator
  • Custom intercooler piping
  • HDI Hybrid intercooler
  • Precision 6466 dual ball bearing T3 turbocharger .82 rear
  • JMF 1.5” ID runner tubular manifold, coated by Hi Octane
  • Turbosmart 45mm Hypergate
  • Turbosmart 50mm Race Port blow off valve
  • Upgraded thermo fan
  • Gates racing Kevlar timing belt
  • ID 2000cc injectors
  • AMS billet fuel rail
  • Turbosmart Fuel pressure reg
  • Dual pumper (2 x 255 walbro fuel pumps)
  • Teflon fuel lines
  • Inline fuel filter
  • 3” custom V band dump pipe
  • 3” custom full exhaust
  • Lightened flywheel
  • Quartermasters 8 leg race clutch (twin plate)
  • Quartermasters hydraulic release bearing
  • STM braided clutch line
Suspension/wheels
  • Ohlins DFV adjustable coilovers
  • Whiteline front swaybar
  • Whiteline adjustable rear swaybar
  • Whiteline bump steer kit
  • Enkei RPF1 matte black 17x8.5 +22
  • Brand new Federal RSR tyres
ECU
  • Haltech PS1000 ECU
  • Haltech ambient intake temp sensor
  • Haltech Oil pressure sensor
  • Haltech wideband AFR sensor
  • Haltech boost solenoid
  • Haltech flex fuel sensor
  • Haltech 4 bar MAP sensor
  • Haltech Race Pack dash display
  • Haltech can bus adaptor
  • Haltech dual EGT sensor kit
Brakes
  • DBA 4000 T3 front slotted rotors
  • DBA 4000 T3 rear slotted rotors
  • Project Mu brake pads
Cosmetics
  • Carbon Fibre boot
Tuned by Powertune Australia making 501.4kw @ 42psi at all four wheels
993077_10152986502470277_1288139203_n_zp
249127_10153355356975277_1243735826_n_zp
1383843_10153355357220277_1044348365_n_z
1383421_10153355356570277_1102688599_n_z
1382273_10153355356460277_1780832686_n_z
1069205_10152986502320277_1464694573_n_z
1006285_10153355356555277_542682507_n_zp
1379237_10153355357120277_431446391_n_zp
1011532_10152986502225277_879817646_n_zp
Edited by Caro
  • 4 weeks later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
