Battery Or Fuel Issue?
Paulie C
 Share
Wondering if i need another battery, (like 2) in the car to help start it or if the fuel pump is dying or not good enough
the issue i had was, left work tuesday on a 32 degree day, went to my local shops, came back to the car and was struggling to start, had voltage from gauge and starter motor was ticking over but no ignition, while this was going on i was pressing the accelerator but nothing was happening, finally it started after a minute of trying on and off with the key and gas.
But i constantly see a issue on hot days were sometimes it seems to bunny hop along from a stand still and i have to floor it for the car to fight through this heart attack it seems to have.
Sometimes the battery/voltage gauge is quite erratic on start up, so i don't know if all the aftermarket parts need a bit more battery juice to get them going. i can even see the headlights dimming up and down aswell as the stock internal clock on the dash
Thought it could be the alternator probably hasn't changed from the factory, when i was turning the key on the day it was at 12 then the next day at 10 and started straight away.
Spoke to my mechanic reckons it could be a hot start issue were it gets to much/ not enough fuel.
So today happened again with the struggle to start while turning the key, got started, then as i was aproaching a turn flicked on the indicator, and my stereo stops playing.
Glance over at the battery gauge and its down to like 9 or 10 then flys back up to 15 and the stereo starts playing again, all happened in like 2 seconds.
  • 3 weeks later...
So been reading through some of the posts before seems a lot of whats happened to other people is the same for me. 1 other post said that they had a blown fuse?
Mechanic changed the fuel to add 20% more on start up and problem still there.
Took it to autobahn they can't find anything wrong, battery's fine. fuels fine. left
Took it to another auto electrician same thing battery's fine, fuels fine, but not really sure, said check the crank angle sensor?
Read that i should let the fuel pump prime, did this so key in ignition half on, and my battery gauge is between 8 then 10 then 11 then 8 then 10 all other place radio kicking in and out after 10 secs car still
Yo!, I was driving back home at 5 sunday arvo and i saw a speed camera, so started turning lights on and off to warn other drivers, every time i turn them on the radio stopped then started hope this narrows down the problem.
  • 3 weeks later...
Yay!!!!!!!!! FML Same problems have re-occured put the key in this morning, half ignition, cd player flashed but didn't come on battery gauge reading 9 -10 volts.
But unbelievably starts without hesitation. Mechanic reckons car is drawing power from some were else and draining the battery.
I should have mentioned a while ago but my boost gauge temporarily works on and off aswell.
I don't have a upgraded sound system. all stock.
 Share
    • Surprisingly the D6000 is only $1999, I'm waiting for the BF/CM sales, and hoping to get one cheaper. D4000 is well priced, still outperforms the 13" SVS PB-3000 and is like 1/2 the price at $1699 RRP. I do watch a fair amount of movies, and listen to EDM, jazz, symphonies, etc. so the lower notes from a subwoofer are always appreciated. The front 8" stage, just doesn't provide you with lively feeling, even though they are pretty bassy for a pair of large bookshelves. Then again, these days it's just playing Wiggles, Blippi and Ms Rachel, another reason the 3m wide cabinet exists, to hide all the audio gear behind it. They used to sit on a nice pair of stands, but as you know, they make good baby traps too.
    • Granted, which is a solid reason why I don't have one. My floorstanders are only -2 dB at 22 Hz.  So they're still working down to <20 Hz. Which is no doubt part of the reason why my receiver shits the bed! That Tonewinner would be about double the cost though, so it's not apples and apples. There aren't many AU$1300 subs (that you can buy prebuilt, I'm ignoring what can be achieved by DIYing) that compete.
    • -6dB at 22Hz isn't that great, watch the data from the D6000 from REW
    • I'll just leave this here. https://www.adelaidespeakers.com/subwoofers.html TL loading, big power. They sound awesome. This is what I would buy if I was going to try to take the bass away from my floorstanders. Just go with the 12".
    • I'll snap up some photos when I'm back home, in the office today meeting my "in the office" quota. Have 2x Teams calls scheduled in, office culture they reckon.   I've never owned a proper off the shelf sub, I've always made or modified broken ones with Jaycar plate amps and/or car subwoofer drivers. The current (and broken) subwoofer has a proper home driver in it, Dayton driver, thos one https://www.daytonaudio.com/product/118/rss265hf-4-10-reference-hf-subwoofer-4-ohm FS of 25Hz, which is low but not low enough. Yeah, I think they were brought out to the market to compete with SVS. I would love a SVS PB-3000 but they're not cheap, especially after their price hike. From reviews online, it does look like the Tonewinner D6000 would destroy and with good amount of money saved too.
