This is surplus to my needs, the delivery of my Avalon unit was actually much earlier than thought
The BFL unit literally arrived yesterday, BRAND NEW! Works perfectly
A solid 30Gh/s of power - Simple to use, plug 'n' play with your mining software of choice
$1100 delivered or best offer!!!!
The quick version - You get rewarded in BTC for supplying the network with CPU power to confirm the monetary exchanges and transactions. The more power you can supply, the bigger the reward.
The BTC you earn, you have transferred to a monetary exchange in Australia that will credit your bank account in dollars, I use www.coinjar.com and withdraw the cash daily, current exchange rate is ~$1000 per BTC
It's a little speculative investment and lots of fun!
What's the payback like?
How long to earn a whole bitcoin?
How much electricity does it use per bitcoin?
EDIT: Actually, if you had one in your house today, it may pay itself off in a few weeks but in 24 months the cost of the power used to mine would be greater than the BC you get in return, so there's money to be made on one for the next couple of years.
Edited by Cowboy1600
What's the best price you'll do on the 50, taking into account it's old tech and you can get a 2x25s for ~$1600 brand new from Butterfly labs - they are ready to ship.
$1600 brand new from Butterfly labs - they are ready to ship......
Check out their shipping costs ;) Then add import duty, GST and the fact that "ready to ship" means........."ready to get the parts off the shelf and build you a bitcoin miner as we don't actually hold stock and make to order"
Dealing with BFL and ordering means you actually get your order 1+ months later
Not being funny at all, but they are very strange in the way they operate.....I can 1000% promise ANYONE that I'd have a brand new 200Gh/s miner in their hands in 2 weeks, BFL can't
I'll do $2000 flat, delivered for the 50Gh/s unit, which should be at least 55Gh/s going by most of the averages I'm seeing from these.
Edited by 666DAN
There wouldn't be any duties, etc, cause I'd get one and I'd get a mate to get one ;) that brings em in at under a gorilla each :)
But $2k ain't bad. I have a little co-op together and I think we're keen. We can't figure out if it'll ever pay itself off or not, but for $500 each we're willing to give it a bash.
I'll be in touch.
BOTH SOLD!
I can get a brand spanking new ASIC 200GH/s Avalon for $4500 if anyone is keen, limit of TWO at this price and only available for the next few days. They land in under two weeks and don't have an owner. Check ebay, second hand ones start at $4000 and go for way more!
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
