Rb20Det R32 Gtst Rough Idle
BaileyH
 Share
Hey guys.
im new to the "SAU", im just wondering if i could get a little bit of help, sorry if the thread is in the wrong spot, feel free to move it.
But, i have a r32 gtst with an rb20det.
It has a rough idle, but when you rev it and its on boost it revs cleanly.
Has anyone had this problem before?
Any ideas on what it is?
I have a feeling its an injector or something :\
I'm having it right now, the brake booster have a little leak from time to time. When it happens the AFR at idle goes up to ~16 AFR (instead of 15), the idle becomes rough and the vacuum lowers to -0.55b.
Mind you, this car has been sitting in a padoc for 6 months plus.
It has old dirty fuel in it.
Its not at my house though yet, i only recently just bought it. But the guy is trying to fix it for me before it comes to mine.
Would old fuel, and old fuel filter make a difference?
No an old fuel will not act like this.
I had my S13 lying for a year before the swap, I managed to start it with difficulty (very very low compression on 2 cylinders), after some minutes of warm-up it ran great. No miss or rough idle, the engine was running on all cylinders and performed "normally".
The old fuel filter if clogged or soon to be will restrain fuel flow so the engine will have difficulty to run when it weel need fuel flow. A friend of mine never changed is fuel filter, when the filter finally clogged, the engine was running like a charm at idle but couldn't move the car, as soon as it was giving some gas the engine would die.
Check for the vacuum leak (especially around the injectors), plugs and coil, rusty earth etc...
It looks like a vac leak, am I sure without having the car under my eyes ? No.
Thing is there is a lot of R&R to search, find and fix a vacuum leak, especially on a RB because the injectors seal are difficult to reach.
You can use some brake cleaner to find a leak with ease. Spray it around all the gasket/vacuum hose you can reach and listen to engine rpm change.
I don't know the RB enough to answer this question.
I didn't wired the OBD light on my S13 and I don't have a consult to check the codes when the leaks on the brake booster appears.
If the OBD light isn't ON on the dash i doubt there is a code to read but double check this with a more experienced RB owner.
No but an erratic airflow signal might throw a code, or the ECU could hit the limit when it's trying to trim the AFR with the O2 sensor. ;)
I don't know if the ECU is advanced enough to find a abnormal behavior from its sensor and throw a code.
The ecu is definitely not smart enough to spot a vac leak .
op have you paid for this car?
It amazes me how people are happy to buy cars woth problems and set a step learning curve for themselves to fix it.
Good luck with it.
Edited by superben
Hey superben, not sure if you're trying to say we are idiots or if you are actually saying its good..
But nah, i know jack shit about RB's.
I told him i dont know much about them, my mate does who is helping me and ive learnt a little bit.
But nah he's gonna fix it and then give it too me. Im just trying to help him fix it, by asking around seeing if anyone else has had many problems.
Im not saying you are an idiot, its just that buying a car with problens is a whole lot of pain, especially if you dont know about what you are buying.
Did you buy it of your mate? In that case I'm sure he will help you sort it, I thought you bought it off someone else who would just say they will sort it but not actually fix it.
Lots of small issues can cause misses.
You haven't mentioned what revs the car is idling at when missing.
I would be checking the timing and pressure testing the pipework to find any leaks, and replacing spark plugs and inspecting coils/ coil loom.
Okay, well my mate who is mechanic said...
"It sounds like a bad plug, or a weeping injector.. More so injector because if its revving clean when on boost it sounds like 1 cylinder is getting a tiny flooded from the weeping injector and is sorting itself out when high revs".
Does that sound right?
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
