Hi all,
As some of you may or may not know i had my car burn down. Im getting rid of a few things laying around that i cant use anymore to help fund solicitor and mechanic bills.
First up is a Power FC with carbon fiber hand controller, I have Z32 AFM that i will throw in for the buyer if you need them $900
I have a brand new set of HID's, These are the real deal and not some ebay crap, Still in the box. They are 5000k, $200
Also for sale
Work BRS Poison.
•Black with Polished Outer.
•3 Piece Construction.
•17x9 +29 Offset all around.
•5x114.3 PCD.
•All centre caps included.
•Come wrapped in Bridgestone Potenza RE-01 255/40/R17 80+% fronts, 50+% rears remaining.
(Can be sold with or without tyres)
•Minimal Dish.
•Tried & Tested, Plenty of room to clear Evo & GT-R Brembos.
•Will need to be cleaned up to be immaculate as the centers are flaking & nicks and scratches here and there on the lips, structurally sounds and no buckles etc...
Price: $1300
Apologies if I sound like a dick, but if they're not OEM then they're not "the real deal". Do have pictures of the ballasts/bulbs/wiring? You didn't state what bulb the kit has (genuinely interested).
Will have some photos up tonight, They are Xenon bulbs.
  • 3 weeks later...
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
