Im after an oil pumpformy gtrand dont really wnat to spend the $1700 or so for a nitto, crank collar and machining, I know rb30's have a different geardesign, narrowdrive and dont seem to crack, however theyflow less. Im planning on running restrictors on the head feed, and a single turbo, which will both improve oil supply to the bottom end, am I mad?
Yep. You are mad. lol
Simon-s14 has a stock na bottom end with stock shimmed pump with 26 head in a drift car. But he is risking a stock sh rb30 bottom end so like 300bucks max.
weigh up the risk and decide
Just got on CT and found that heaps of people are running a8(turbo) pumps in big hp/8000rpm cars running down to 9's, just never heard of vls breaking pumps, seems to be a skyline thing. If simon s14 is running a stock na pump, then it would have even less load onthe drive flats, as they flow even less, wonder what his oil pressure is like
Edited by Adriano
Don't forget though they are all auto, leave the line off a loaded engine/transbrake and you never see them sitting on limiters during burnouts. Definately big factor differences.
It's certainly not the RPM that's the problem on a well balanced motor.
Where did you get $1700 for crank collar and install from? The collar itself is $150 and I had a wide crank collar fitted to an rb25 crank for a little over $100. Even if having the crank micro polished, straightness/crack/balance checked and grub screw cleaned you'll come in at well under a grand.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
