My clutch plate  is making weird noises when i reverse and when i put my clutch in the revs idel down .. to the point that it almost stalls.
I have a brass button puk clutch...
Whats the deal homies?  I only got this thing put in like last year?  :nowigetit
there might be a problem with your thrust bearing thats making that noise but sounds like its not disengaging properly too thats why its almost stalling see a clutch guy PVP i would see he is good with that sorta stuff on muller road
Does the clutch engage at the top of the pedal travel? Have you checked master and slave cylinders are fully tightened in place? Checked the clutch pedal mounting under the dash? There should be enough adjust that you can stop this happening - as it sounds like the clutch isnt fully disengaging.
A few things to look at anyhow.
Guest Miss_Nismo
Gee Erica should I bring my overalls around and we can snap to it? I'm sure we can figure that out being the mechanics that we are :nowigetit
Definately sounds like the clutch isn't disengaging.
Check the master cyclinder for leaks on both the inside of the firewall and the outside. (Mine was leaking on the inside down the firewall and down the clutch pedal)
Flick the rubber boot on the slave cyclinder and check there isn't any fluid in their. If there is then chances are its leaking and letting a little bit of air in the system causing the clutch not to disengage.
I had a similiar issue. My master cyclinder was stuffed. I poped down to some brake and clutch joint behind the caltex servo on south road at St.Mary's. The bloke there has a R33 Skyline and knows what parts to use. The master cyclinder from memory cost me $65.
EDIT: The shaft that connects to the clutch pedal can also be adjusted.
If its only started doing it then I'd say it isn't the adjustment but air in the system or if your really unlucky the clutch fork could be farked.
