Hey guys, just fit a Bee*R to my Z32 the other day and I'm having a problem with the rev2 setting. Wired it into the handbrake switch and it activates just fine, however when I try to set it on the dial anywhere between 0-6 it will just go between 2500-3000rpm all the way until 7 when it jumps to 6000rpm. Rev1 setting works perfectly fine though.
Now I'm fairly sure my unit is genuine, though I did buy it second hand. The other thing I've noticed is that when adjusting the dials at idle the engine seems to have a bit of a miss every time the dial clicks across. Does this happen to others or is it possible I've got a faulty unit? I've tried searching already but I couldn't come across anything similar to what I'm experiencing.
https://www.sau.com.au/forums/topic/437418-beer-limiter-problem-questions/
