Hi guys,
I am asking for opinions here as per heading, please only post based on personal
Experience not a mate or a mate of a mate had....
What i am after is a engine management system that does the following:
Shows live data on how the motors running
Shows faults like a diagnostic tool and can clear codes
Boost control
I would like to know what brand and model i should be looking at and why.
My car is an r34 gtt.
Thank you in advance to anyone that replies
Pete
You need to give more info, like why you want that and what your power goals are.
For example, nistune will do all that except for boost control.
Keeping the factory ecu also means you will have everything working as it should, cold start perfect, idle control and not be an instant defect.
Edited by superben
Excuse my lack of knowledge but does the apexi unit show fault codes? Also
Is it able to clear them?
It shows, far as I know, all sensor faults via the hand controller.
For what you want just get Nistune and a blitz boost controller separate, job done for roughly $1,000 not not including tune or install. Won't find better than that
Thank you all that replied. I have researched the to main options
Being the apexi pfc and the nistune setup.
At this stage I think the apexi pfc will be the go for me
All be it that im not a huge fan of the look of the hand controller
Personally I think they could have done better on that front
But it seems to be what I'm after.
Cheers guys.
Ps will be signing up to sau vic and look forward to putting faces the names
Pete
Although the Power FC is fairly basic compared to most of the top replacement ECU's, the hand controller is an awesome feature.
I've had a Power FC in my car for the last 10 years and have recently fitted a wide band sensor with an in car display. I just wish I fitted the wideband around 10 years ago! It has given me the ability to fine tune the low end part of the tune and get it much better than I've ever had from a dyno tune (my car is also a daily driver).
Due to the monitoring ability of the ECU, coupled with the wide band, I am now able to diagnose most faults on the fly without having to dump it with a mechanic saying "it's not running right". I recently found my Fuel Pressure Regulator had failed, without having the real time monitoring of everything this could have been a costly exercise for a mechanic to trouble shoot.
So yes go for the Power FC, with boost controller (I use an Eboost Street) and I'd strongly consider having a wideband fitted. Mine cost around $400 - just make sure you get the sensor bung welded in the correct position, as the stock narrow band location is too close to the turbo for it to read accurately (mine is just forward of the CAT).
Power FC is good ecu that if you can find one for 34 GTT at reasonable $ - they're different to 33 just so you know.
I'm planning on putting Adaptronic plug in mine but I'm looking to move my 34 for another GTR, I've told/read good things about them and it's pretty good kit, definitely worth consider if you're having trouble getting a Power FC.
Edit; Should add, pity the Adaptronic doesn't come with hand controller of some sort but you're provided with a usb plug that you could plug into your laptop with software from Adaptronic themselves - that is what I was told by couple of friends.
Edited by Count Grantleyish
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
