Fs: Wrecking 1996 R33 Gtst White - Townsville
Hey guys,
In the process of completely stripping down a white 1996 R33 GTST located in Townsville. Heaps of parts up for grabs so if you want something specific let me know.
Would prefer local pickup but small parts I don't mind freighting.
Some prices and parts include:
Aftermarket parts
Plazmaman plenum and Plazmaman throttle body
Aftermarket billet fuel rail - $50
Built long block engine (refer to my other for sale thread on the engine alone) - $5000
Garret GT3540 1.06 exhaust housing, 6boost, tial gate, screamer, dump pipe, intake pipe and K&N filter - $3000
Splitfire coilpacks (S2 GTST and R34 GTR)
Tial BOV on intercooler pipe with v-band flange - $200
Koyo radiator and shroud
Greddy front mount and intercooler piping
Link G3 plug and play ECU
Front aluminium strut brace
Fibreglass rear bumper (unknown brand) - $100
Fibreglass front bumper (Trust style)
Boss kit
3.5" X-force exhaust system with Varex muffler and decat pipe - $500
Rockford Fosgate 6.5" component speakers
Rockford Fosgate 6.5" co ax speakers - $50
OEM parts
5 speed manual with Exedy twin plate clutch (worth over $2000 alone)
Front and rear brakes with DBA slotted rotors, brake lines and EBC Red Stuff Pads - $1000
Alternator - $50
Starter motor - $40
Power steering pump
A/C compressor
CAS
CAS bracket
LSD diff
OEM suspension
Master cylinder
Stock wheels with tyres (6 available) - $50 each
Series II headlights
Series II front grille
Drift lip rear spoiler
Boot lid
Side mirrors
Bonnet - $200
Rear tail lights - $50 ea
Reo bar
Front Seat belts - $80 each
Rear Seat belts - $80 for all
Passengers side front guard - $70
Door cards - $100
Passenger side window switch - $50
Centre console with armrest - $80
Heaps of other parts available just hit me up. More than welcome to come and have a look at parts first.
Thanks guys.
Phil
  • 2 months later...
  • 2 months later...
  • 4 weeks later...
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
