I have a few left over parts for sale that i need to sell to fund a Haltech and 1400cc injectors
RB30 A8 turbo block Has been freashly honed and decked and primed and painted House Of Kolour candy apple red over a gold base will be fine with heat and also comes with a freashly ballanced and preped crank. It is also drilled and taped for 12mm ARP head studs and tensioner is also drilled and taped
(87mm) N.O.: 040727 A8
$500
HKS cams that came with a spool imports race prep head package. These cams are rare and hard to find now. The specs are HKS 272 deg 9.35 lift
$800
Rb26 plenum and throttle bodies
$450
RB30/25 flywheel has been freashly machined and lightend by Direct clutches in brisbane
$150
This is a vid of these cams and this block getting dyno befor the motor was striped down and refreashed. Gives a bit of an idea on the note of the cams
Contact Monty on 0439 592 916 or reply on here pics below
https://www.sau.com.au/forums/topic/437435-fs-rb30-a8-and-rb26-parts-hks-cams/
Do the cams use a standard 32mm base circle, is the head relieved for lobe clearance, any part numbers, sorry for all questions, just trying to find out if they are what I'm looking for
yeh the head was machined for lobe clearance. only details that i know is what i wrote down and that they are rare. I didnt want to sell them but need to finishish this motor to get the car on the road been 3yrs now and only need ecu and injectors. sorry i cant help you more. They measure 32.5mm over the base and 41 from the base to the tip of lobe
Cheers for the reply, looking for straight drop in, may go 270 poncam. I feel your pain put a 26/30 as well as many other things in my 33 s2 gtst and spent 3 years off the road also
  • 1 year later...
