Hey guys did a search but couldn't find much info, I was thinking of replacing the centre tripple gauges in my 32gtr with some better aftermarket ones but I was thinking oil pressure oil temp and boost seem like a good idea but there is already and oil pressure on the dash cluster, so I thought maybe I could take the oil pressure lense off make or get made a new lense and have volts and water temp in the cluster, and then I wouldn't have 2 gauges for oil pressure. So my question is can this be done and has anyone done it. I was thinking maybe if the volts gauge motor/ actuator fit where the oil pressure is ment to mount I could re wire the connection to the cluster to read volts, well I'm guessing they just read voltage and display by input voltage or whatever but being only battery it shouldn't be too difficult
And then run all aftermarket wiring for the new centre gauges.
https://www.sau.com.au/forums/topic/437436-r32-gtr-dash-cluster-mod/
