link? or contact details?
B-Man how do they compare to UAS?
They are both great - but different in their own ways.
Just go to both and check them out for yourself.
Nathan is a tops guy - a real skyine enthusiast.
John from UAS is good too - but he likes V6 engines for some reason :D
  • Replies 76
yeah went to nath on the advice of this posts and man what a guy.. he solved my stalling problem by just tuning the avcr which was playing up my A/F ratios. And only charged me like 50 bux to fix it and this was on a sturday when he was quite busy what a guy. Now the car runs sweeeeett. Im going back there again for sure.
cef.
Re dyno he doesnt have one in shop but I dare say he would have ties with someone, Lazza, he wouldnt have any dramas doing the work I don't think, but call him and ask, tell him Andrew, Duncan, Fatz or Tosh or whoever else has posted in here said he is good for it!! 9519 5150
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
