Hi guys,
I was wondering if someone in the Sydney area can help me out. I'm currently looking at installing 2860-5 to my car. I have purchased everything that I need to do this.
The drama I'm having now is the thought of going straight to a single gt35r or simular. I really want to make sure I will be happy with the /5's. can anyone in Sydney take me for a spin? (you drive of course) so I can be sure I am doing the right thing :pi really want to feel how the power is delivered. No point on going to all this effort for disappointment when I could have done it another way in the first place.
Can meet at a maccas or servo of wherever required. Would really appreciate it!
  • Replies 50
What capacity is your motor?
What kinda power are you chasing?
What fuel will be used?
Driven 5's on a 2.8L and hold the faaark on after 4K on a 2.6L id say itd take around the 5K+ zone before things get exciting ;)
Andy i have the t517z 10cm on mine and i can show you that, ive gone straight to a gtx3076r (sitting next to me right now <3) because unless you plan on building your engine the gt35 is too big and lagy for the standard internal 2.6 You can push the gtx3076r to 400+kw on e85 and anything past that on a standard block and your asking for trouble. Ill only have these turbos on the car for the next few weeks then its all coming off for the single.
Hey mate, keeping it a 2.6 for now. Chasing 350kw+ on e85. Stock bottom end.
Yea mate, pm me your number. Would love to come around and check it out. About due for a catch up anyhow. I'm going to keep stock internals for now and see how far we can push it. I may look at a rb26/30 if or when she blows.
If your chasing 400, get ready for disappointment...
Hey may not make those numbers... Even on e85. But it would be as responsive as hell.
No, sorry, -5s will make it on e85 easy if everything is sorted. Heaps of examples of it in the 400kw thread.
The gtx3076, I don't think will flow 400kw except when the setup is tip top and turbo is all in. I dunno why you'd go that route over the 6262 which seems to be more popular these days.
Not many people run gt30 singles on 26s.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
