Hi guys,
I was wondering if someone in the Sydney area can help me out. I'm currently looking at installing 2860-5 to my car. I have purchased everything that I need to do this.
The drama I'm having now is the thought of going straight to a single gt35r or simular. I really want to make sure I will be happy with the /5's. can anyone in Sydney take me for a spin? (you drive of course) so I can be sure I am doing the right thing :pi really want to feel how the power is delivered. No point on going to all this effort for disappointment when I could have done it another way in the first place.
Can meet at a maccas or servo of wherever required. Would really appreciate it!
  • Replies 50
What capacity is your motor?
What kinda power are you chasing?
What fuel will be used?
Driven 5's on a 2.8L and hold the faaark on after 4K on a 2.6L id say itd take around the 5K+ zone before things get exciting ;)
Andy i have the t517z 10cm on mine and i can show you that, ive gone straight to a gtx3076r (sitting next to me right now <3) because unless you plan on building your engine the gt35 is too big and lagy for the standard internal 2.6 You can push the gtx3076r to 400+kw on e85 and anything past that on a standard block and your asking for trouble. Ill only have these turbos on the car for the next few weeks then its all coming off for the single.
Hey mate, keeping it a 2.6 for now. Chasing 350kw+ on e85. Stock bottom end.
Yea mate, pm me your number. Would love to come around and check it out. About due for a catch up anyhow. I'm going to keep stock internals for now and see how far we can push it. I may look at a rb26/30 if or when she blows.
If your chasing 400, get ready for disappointment...
Hey may not make those numbers... Even on e85. But it would be as responsive as hell.
No, sorry, -5s will make it on e85 easy if everything is sorted. Heaps of examples of it in the 400kw thread.
The gtx3076, I don't think will flow 400kw except when the setup is tip top and turbo is all in. I dunno why you'd go that route over the 6262 which seems to be more popular these days.
Not many people run gt30 singles on 26s.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
