Hi All,
I recently broke 3rd on my standard 'box but am really confused about what to replace it with..
The car is mostly used on track, is full weight,440bhp@hubs and runs rederal RS-R's.
I've found a second hand good condition R33GTR G'box fitted with OS Giken 1-5 + centre plate and seen that some people are using the R34 Getrag with good results.
What I'm sure about is that I don't want a dog box and will never be able to afford a Hollinger! Also, I don't want another standard 'box as I'm sure I'd break it..
One day I'd like to have 500bhp + @hubs.
Any suggestions/advice?
Thanks in advance all :)
Cheers,
Sam
https://www.sau.com.au/forums/topic/437499-what-gearbox-to-use-r32-gtr/
A GTS-t box is more or less the same as a GT-R box..
Anyway with only 440hp you shouldn't be breaking any boxes TBH. That is more than within the realm of reliable. The clutch can be a typical factor to causing box breakages (ie, the wrong type etc).
I have an R33 GTR box in my full weight Stagea with about 420awhp and it is going fine after about three years of being used as a daily and about 6 track days a year. I have a super strong (high clamping pressure) single plate clutch of unknown Japanese brand. If you rebuild your box there should be no inevitability about your breaking it and people are running standard boxes let alone those with OS gear sets with well over 500hp without breaking them.
Thanks a lot folks for the replies:)
I wish I hadn't broken it!
With the dog box, I just want to keep a certain amount of road worthiness and for some strange reason have a desire to do some sort of long road trip to Europe (I live in London uk) ... A dog box I think would get on my nerves.. I've seen the ppg vid on YouTube and understand they're not that bad, just not for me.
The car makes just over 500bho at engine, I'm sure if I wasn't chasing lap times it wouldn't have broken but am equally sure that if I put another standard box I'll have the same problem. If not now, certainly in the future with more power:(
I got the standard box rebuilt only 10 months ago - wish I'd upgraded then.
So if I'm not going for a dog box, the options I'm considering are Os giken 1-5 and getrag conversion. Is there anything I haven't thought of that I should consider?
Any idea on which is better?
Thanks again for your help:)
Sam
Thanks for this... From the info I've seen a lot of people have been running a lot of power through the getrag and the ones I've had contact with all recommend it.. They've all said they've been through several standard boxes then didn't have a problem once the getrag was fitted other than bearings and synchros.
I did read 'tyndagos' comments that with around 500 bhp the getrag breaks the baulk rings with circuit use, the 5 speed breaks the gears at the same power level but the 5 speed fitted with os giken internals can be good for around700..
I've spoken to someone that was racing with the os giken kit at over 800 bhp and made it last.. (This car put in slower lap times than mine though so it's hard to compare). Apparently it's something to do with a bearing or standard part that needs upgrading but I have very limited understanding of this sort if thing!
I'm kind of thinking you're right about crossing the getrag off the list especially if a good second hand os giken box can be had for the same money or less..
I'm just finding it really hard to get good advice from people that have used their cars for hard lapping of a circuit for 5+ mins.
Most people in the uk only use their skylines for drag racing..
So many variables!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
