For sale is my Hypergear Ss2 turbo that is now off the car. Internal gate
It is approximately a 3076 equivalent.
Turbo has had not much time on the car.
Was purchased late 2012, but then car was off the road for a year. Turbo was opened and rechecked by Stao last year. And the turbo has done 1 track day and a few thousand KM's.
Turbo made 280rwkws. (20psi bleeding down to ~16psi) Turbo housing has been ceramic coated by HPC in their top TC1 coating.
Turbo cost $1,450 new + $220 + postage for the ceramic coating
$1,100 ono. Pickup from SE Melbourne
Reason for sale: Have upgraded to a bigger turbo.
Turbo is in tip top condition and can be inspected
https://www.sau.com.au/forums/topic/437501-hypergear-ss2-turbo/
In case someone is looking at this but has yet to see the HG thread, link is here - http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/
The SS2 is probably the perfect turbo for a daily driven RB25. Tony's price is a ripper, too, when you consider it's almost new and has been coated.
Power was on pump 98
Actuator was i think 18psi one? Ill have to check with Stao, but i have both a 16psi and a higher psi one.
You can have both actuators in the sale
Bleed off is just due to turbo, but im sure if you send this turbo to Stao he can update it so it holds boost till redline. He offered to this for me for a small fee.
Guys that have held boost have made about 300rwkw on 18psi off the top of my head
How much of a "small" fee if you can remember?
I've just asked Stao. Will cost $250.
You'd probably only go this route on a built engine imo. Don't think you would want to run anymore than 280rwkw or 18psi on a standard engine on pump 98.
Ok last chance $950 pickup otherwise ill be sending it interstate most likely
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
