SAU GT6 SUPER-LAP
Vehicle Regulations:
- The car must have originated from a stock Japanese production car, no Racing cars allowed (SuperGT,MINES,HKS ect.)
- Any kind of performance tuning is allowed (apart from tires and Nitrous).
- Nitrous (NOS) is NOT permitted.
- Tires used must be street legal, max tire is Sports Soft (S3).
Track:
Mount Panorama
Event Regulations:
- Lap must be done in Arcade Mode Time Trial.
- Fastest lap must be clean with a maximum of 2 wheels coming off the track at any one time. Run off areas such as on the main straight and hairpins count as part of the track.
- Save fastest lap replay.
-If your time beats the record then you can submit the replay. (If it's not to much trouble)
Safety Rules (Optional)
  1. Helmets complying with a minimum AS1698 or as per the requirements of the organisers of the event. Must be in good condition without any perforations to the outer surface.
  2. Footwear, socks and gloves made from flame retardant material complying with FIA 8856-2000.
  3. Anyone playing outside , goggles or a visor with a lens material other than glass (ie to AS1609-1981) are mandatory.
- Submit:
Fastest Lap Time:
Name:
Car Used:
https://www.sau.com.au/forums/topic/437515-sau-gt6-mt-panorama-super-lap/
  • Replies 44
Posted Images
Ok, well I might as well be the first to post a time.
Time: 2:03:599
Car: r35 gtr black edition '12
Mods: everything (but no running to suspension, etc)
Shouldn't be too hard to beat, since I crossed the line backwards in a cloud of smoke after a massive tank slapper, lol. And I had a big moment coming into the cutting where I lost a few car lengths on my previous best time
Fastest Lap Time: 2:02.025
Car Used: R34 GTR V-spec II
That's a good lap. I was stuffing around and did a few laps in my r34 n1 and I only did a mid 2:05. It was a sloppy lap, but not sure that I'd get over 3 seconds more out of it, at least not without playing around with the tuning
You buy me one, as well as a house big enough to allow me to set it up and I'll use it.
You can get steering wheels cheap, and you don't need a big house I sure don't have one. You just have to get creative
Good to see some times going up, hopefully I can get on this weekend.
I live in a 2 car garage and play the ps3 on my bed......
But anyway, I discovered that I hadn't changed the oil on the cars I was having a go with, so I did that, gained some horsepower then had another go.
Car: r35 gtr black edition '12 (same as earlier)
Time: 1:58.560
Pretty happy with that, but reckon I might be able to crack into the 1:57s if I sat down for longer and really had a proper go and played with the tuning of the car. Also got my r34 (well different r34 to the one I used before) into the 2:02s with a few mistakes.
Nice times Marc, yeah I used to live in the garage many years ago when I still lived at home. It was awesome for awhile but the f**king Mosquitos would find their way in! There's quite a few simulators that fold up and can be stored in small spaces. Or just bung some hooks in the roof and put it up there :) it's all about gran tourism and you gotta get creative. You can notice the difference in the handling of cars and get a better feel for the game with a steering wheel. Anyway the more ppl who join us the better, steering wheel or not..
If someone can edit the leaderboard that would be awesome.
Time: 2:02:120
Car: R33 GTR v-spec
Steering: Wheel G27
1:58's pretty fast mad082. I reckon I can get in the 1:59's with some tunning. Got to sort the suspension out.
Edited by dyl33
Yeah 1:58 is fast. I don't think I could get below 2:00 in an earlier gtr than the r35. The 35 is a totally different car (the 34 is more fun though). It's more stable across the top of the mountain, (although it understeers more coming down the mountain) and the fact that it has about 300hp more power (although it's also heavier). I'll have a go with some different cars tonight if I get a chance. I'll try a lancer, etc.
Tine - 1:58.452
Name - Nismon1
Car - R35 12 Black Edition
I think there's def a 1:57 in it, as out braked myself and ran wide on a fair few corners.
35 is fast, but for fun, gab a MP4-12c, tune it with everything and give that a rap around Bathurst. Awesome car, but hard to tame and can only do a 2:01 in it
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
