  • Replies 44
Posted Images
I reckon I can get into the 1:55s. Just did a 1:56.395 with a few small errors. The following lap I was .23 faster at the first check point (halfway up the first straight) before I cocked up my braking point and drilled the wall
nice lap mad,
and have to agree. I just watched my replay and massive lock up running wide all the way into turn 2, and a stuff up here and there up around the top.
Also there's probably heaps of time in playing with the suspension
But this is fun, was getting starting to get bored with it but now have something to go for :)
new best time. 1:55.834. i definitely have a mid 1:55 there for the taking, but we are talking no mistakes to do it. on my 1:55 lap i was 0.906 up on my 1:56.395 lap at the final split (halfway down conrod straight). when i saw that come up i just did my best to keep it on the track and was a little bit over cautious into the last corner, and had a small moment up near reid park). the lap before that one i was 0.7 up at the last split and then cut the corner coming out of the chase a whisker too much and got the lap invalidated, so i didn't want to lose my super lap.
oh and i agree about having something to chase. it certainly makes licence test more entertaining as i usually have a crack to get the best time, or at least not the slowest, lol. although on the seasonal event for the ft-1 i did tonight i only did 2 laps to get the gold and couldn't be bothered trying to get a better time.
jeez, fast times in the R35s! i knew it would be quicker than the R34 I chose, but 6.4sec is alot! I just can't bring myself to buy a 35...
Tried an LFA but they just don't make enough power to be competitive. The JZA80 Supra does have the power, but Gran Turismo has never blessed the Supra with any traction at all. In the end they both run about 2:05.
The Honda NSX LM Road Car would probably give it a nudge, but that's not really a stock Japanese production car...
I might try a Z32 for a laugh.
Had a go with the r34 again. Managed to crack into the sub 2 minute bracket. 1:59.289. It was a super tidy lap. Still a tenth here or there to be had, but not much. Found a few lines that seem to work a bit better in a few spots so going to give the 35 another go
New record
Time: 1:55.207
Car: r35 gtr black
There is a 1:54 in that car. I did a 1:55.447 and then did a lap where I was 0.955 up at the last check point but went too cautious into the chase and the last corner and only got a 1:55.295. When I set the .207 lap I also managed to get the 3 magnificent laps trophy as the 2 laps before it were both low 55s. Had a bit of a zone going
1:59.289 in the 34 well done mad.
I got last night
Time: 2:00.580
Car: R33 GTR vspec
Still a pretty messy lap some lines I can do better
Still think I can get high 1:59's. I've kinda mangled the suspension and gear ratio settings so will have to sort that out again.
This is the most fun I've had with gt6 so far. Tried on-line last night and that was unbearable.
Had a bit of a play with my 34's setup and got a 2:00.372
Then gave in an bought an R35 Black. What an animal! 1st lap full power and lightweight mods but stock suspension and driveline, no wing, just the flat floor: 1:58.812. Soooo easy to drive after the R34! Then added clutch, tailshaft and LSD, still on stock suspension & no wing. Went back out and reeled these 3 laps in succession
1:57.367
1:56.714
1:56.015
before almost rolling it at the end of the next lap - don't clip the final kerb at Murray's corner!
1:57.367
1:56.714
1:56.015
I've only got 1:57 in the 35.
haha that brings new meaning to fully sideways
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
