Gates Racing High Performance Timing Belt.
New Never USED RRP $110+
Product Benefits:
- 300% Stronger Than OEM Belts
- 3 Times More Head Resistance
- Exceptional Durability
- Wear Resistant Teeth
- Robust Reinforced Tooth Jacket
- Super Strong Tensile Cord
- Perfect For High Horsepower Engines
Engine Compatibility:
- Nissan RB20DE/RB20DET
- Nissan RB25DE/RB25DET
- Nissan RB26DETT
$75 Cash pick up from Werribee area
$20 Postage with tracking
$25 Postage with Signature.
Edited by Sydneyactionman
    • Holy hell! That is absolutely stunning! Great work!!!
