Hi all,
Recently pulled the stereo out and replaced it with a Pioneer unit, painting the black plastics at the same time. However, the radio reception wasn't great - when we held the harness (including bracket, Climate control, single din head unit and ashtray) before screwing it in we were getting amazing, loud, crystal clear reception. However, as soon as we screwed it all in, the clarity faded, though you can still hear the radio fine. We're going to try again this weekend and get a good ground going - we feel it may have been grounding through the antenna.
While the stereo was out, we found a pair of TV 'bunny ears' antenna (from the jap install with previous headunit that had TV function? The TV never worked for me).Also, there were quite a few proper connector plugs unplugged - is this where the automatic models would be plugged in? My vehicle is manual. I also found some RCA cables (L and R) that seemingly didn't fit anywhere. It seemed that when i turned the ignition 1 click when they were unplugged, there would be lots of whining noises coming from the dash. However, when they were plugged in, this seemed to subside - even if they weren't plugged into anything with output.
Curious, i opened up the boot and took off the little cardboard/carpet section between the boot and the rear seats, and found these things (pictured) near the rear speakers on the parcel shelf. I receive frequencies for Triple J 105.7 and Triple M 104.9, so obviously at some stage in Australia (vehicle imported 2004 i believe, 1998 R34 GT-T) i had an FM expander installed. There is a 'Diversity' plug/antenna thing behind the stereo i believe. Are these things antenna amplifiers, or are they to do with the Hicas? I have had no experience with this before.
Because of the RCA cables, (and whatever that thin blue wire is?) I suspect that the previous owner had amp and subs installed, and pulled out the power cables, when he sold (as well as the amp and subs - i own neither) because i can not find anything connected to the battery. If anyone could shed any light on what these things are, and possibly go all Sherlock Holmes and tell me what the previous owner got up to, it would be much appreciated! Finally, any suggestions on how to clear up radio reception is also welcome! will provide further information once i open it up again this weekend
Cheers,
Mick
I guess it can't be anything interesting then, which is really what i wanted to know. I have a pdf of the workshop manual at work, will have a dig around in this (on company time ;)
    • It's a fun daydream but personally just looking at OEM implementations of twincharged engines like the recent Volvo engines it makes my head hurt. So, so much complexity compared to even other GDI turbo inline 4s.
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
