I know they are quiet and very different,but this is the future guys.Just look how well the electric cars went at Pykes Peak last year and also the fastest electric drag bike isnt far off Top Fuel bike times.Anyone used a latest technology electric remote control car lately,yes they can beat the little petrol ones now.Wont be long until one can beat a petrol powered F1 car.Sorry guys its just the way it is.Electricity has huge amounts of potential power,we are just learning how to store at properly.
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7171051
The problem I see is most people actually like that race fuel smell and the sight of flames flowing out the exhaust, exhust pops between gear changes, fuel catching on fire during pit stops etc etc. I wish these nobs with more money then sense would put more money into Hydrogen Based fuels and STOP dicking around with Electric Cars and the like.
With a world so dependant on Fossil Fuels which in turn is also used for Creating Electricity this just seems stupid. Reason why is if EVERYONE was to drive an Electric car the demand on Electricity will go throught the roof, more fossil fuels to be burnt to create more electricity to power all these Electric/Power demands. So saving the Earth from ZERO exhaust gases is pointless unless they can create a CLEAN or GREENER way of powering up these electric vehicles and better disposal of the batteries.
I may be totally wrong in my thoughts but thats just how I see it.
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7171109
My mate has one and the thing is ridiculously fast.. You can be going along at almost top speed for a long distance, then pin the throttle and the car will still stand up on the rear and flip itself lol
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7171759
  • 7 months later...
Their "Pit stop" involved jumping out of the car at lap 14, and getting in another blender to finish a 25 lap race.
Hardly enthralling entertainment.
Because batteries went flat?.....they should have a 24 hour race...he with the biggest battery charger wins....
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7388610
Classy work from the other driver just to walk away without even looking to see if Nick was OK.
Can't believe he was able to clamber out and run after a shunt like that! Scary looking stack!
and that's the most exciting thing that will ever happen in F.E.
treaded tyres? FFS
Edited by hrd-hr30
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7388838
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
