I know they are quiet and very different,but this is the future guys.Just look how well the electric cars went at Pykes Peak last year and also the fastest electric drag bike isnt far off Top Fuel bike times.Anyone used a latest technology electric remote control car lately,yes they can beat the little petrol ones now.Wont be long until one can beat a petrol powered F1 car.Sorry guys its just the way it is.Electricity has huge amounts of potential power,we are just learning how to store at properly.
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7171051
The problem I see is most people actually like that race fuel smell and the sight of flames flowing out the exhaust, exhust pops between gear changes, fuel catching on fire during pit stops etc etc. I wish these nobs with more money then sense would put more money into Hydrogen Based fuels and STOP dicking around with Electric Cars and the like.
With a world so dependant on Fossil Fuels which in turn is also used for Creating Electricity this just seems stupid. Reason why is if EVERYONE was to drive an Electric car the demand on Electricity will go throught the roof, more fossil fuels to be burnt to create more electricity to power all these Electric/Power demands. So saving the Earth from ZERO exhaust gases is pointless unless they can create a CLEAN or GREENER way of powering up these electric vehicles and better disposal of the batteries.
I may be totally wrong in my thoughts but thats just how I see it.
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7171109
My mate has one and the thing is ridiculously fast.. You can be going along at almost top speed for a long distance, then pin the throttle and the car will still stand up on the rear and flip itself lol
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7171759
  • 7 months later...
Their "Pit stop" involved jumping out of the car at lap 14, and getting in another blender to finish a 25 lap race.
Hardly enthralling entertainment.
Because batteries went flat?.....they should have a 24 hour race...he with the biggest battery charger wins....
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7388610
Classy work from the other driver just to walk away without even looking to see if Nick was OK.
Can't believe he was able to clamber out and run after a shunt like that! Scary looking stack!
and that's the most exciting thing that will ever happen in F.E.
treaded tyres? FFS
Edited by hrd-hr30
https://www.sau.com.au/forums/topic/437588-formula-e-2014/#findComment-7388838
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
