post-131888-13897031314438_thumb.jpgpost-131888-13897031567392_thumb.jpgpost-131888-13897031993123_thumb.jpgpost-131888-13897032234805_thumb.jpgpost-131888-13897032468765_thumb.jpgpost-131888-13897033125363_thumb.jpgpost-131888-13897033345293_thumb.jpgpost-131888-1389703354287_thumb.jpgpost-131888-13897033704331_thumb.jpgpost-131888-13897034211976_thumb.jpgpost-131888-13897034545537_thumb.jpgpost-131888-13897036205329_thumb.jpgpost-131888-13897036549825_thumb.jpgEngine Accessories:
post-131888-13897037566992_thumb.jpgpost-131888-13897037844813_thumb.jpgpost-131888-13897038029686_thumb.jpgpost-131888-13897038327039_thumb.jpgpost-131888-13897039776708_thumb.jpg
Engine Accessories:
Polished Rock cover / Valve cover
TOMEI Coil Pack Cover
TRUST Oil Sump
TRUST 13 Row Oil Cooler and Filter Relocation kit
Nismo Brake Cylinder Stopper
ARC Intercooler (cross flow)
Apexi Air Intake
Mishimoto custom Radiator 60mm core w NISMO 1.1bar Rad Cap
SARD Drain Plug
HKS Super Dragger Exhaust
HKS Exhaust Manifold
HKS Front Pipe
TOMEI Dump Pipe
TOMEI Down Pipe
TOMEI Exhaust Turbo Elbow Outlet Pipe
WALBRO 255L Fuel Pump
Exedy Lighten Flywheel
EXEDY 5 Puck Button Metal Clutch
Exterior:
ORIGIN LAB AeroKit Aggressive Carbon Fibre Front Bumper
ORIGIN LAB AeroKit Aggressive Carbon Fibre Rear Bumper
ORIGIN LAB Aerokit Aggressive Carbon Fibre Side Skirts
ORIGIN Carbon Fibre Front Bonnet
ORIGIN Carbon Fibre Rear Trunk
ORIGIN Carbon Fibre Front Wide Fenders (25mm)
ORIGIN Carbon Fibre Rear Wide Fenders (40mm)
Craft Square Carbon Fibre Mirrors
NISMO Smoked Side Blinkers
Custom Paint w Pearl and Flakes : Full Exterior, Interior, Engine Bay, Rims: $9,000
HANDLING:
Brown Davis Roll Cage 7 point full black casted (FIA Approved)
R34 GTR Brembo Brake Calipers 4 Pot (front and rear)
Project Mu Rotors
GOODRIDGE Steel Braided Brake Hoses
APP Brake Pads
R34 Brake Hub
R33 Rear Knuckle and Handbrake Assembly
Aluminium Subframe Bushings
NISMO 2 Way Mechanical LSD
TEIN Monoflex Suspension w EDFC Controller
CUSCO Front Strut Bar
NISMO Front Lower Brace
NISMO Rear Strut Brace
NISMO Toe Arm
NISMO Lower Control Arms
NISMO Upper Control arms
NISMO Traction Rods
Interior:
MOMO Champion Steering Wheel
NISMO Face Dial speedometer
Works Bell Rapfix GTC (hub and tilt kit)
Momo Boss Kit
Nismo Shifter knob
Sound System:
Rainbow speakers
Kenwood amplifier
Pionner GPS double din
Wheels:
PROJECT D rims (custom gold painted)
18 X 9 FRONT
18 X 10 REAR
Advan Neova AD08
(265/35/18, 245/40/18)
I have most stock parts available.
Optional (sold separately): $10,000
MOTEC M800 (Gold Box)
- M800 Advanced Functions Upgrade
* Traction Control
* Overrun Boost Enhancement (Anti-lag)
* Gear Change Ignition Cut (Flat Shifts)
* Variable Camshaft Control
* Data Logging
* Wideband Lambda
* Delco 1 bar Map Sensor
* Cut-to-Fit Loom (2.5m unterminated)
* Bosch 033 201 4112 Relay
* Bosch Relay 4973 Connector
* 34 Pin Superseal Connector Kit for M800
* 26 Pin Superseal Connector Kit for M800
* Wiring adaptor to Factory Harness (solder) (change to Standard ECU anytime)
Used Items for MOTEC assembly:
- Pin for M800 Superseal Connector Female
- Splice Terminal (small, large)
BRAND NEW ITEMS: Optional (sold separately):
- MOMO Drift Limited Steering wheel (Gold)- $280
- DRIFT Pod filter w custom Aluminium Pipe- $60
- Custom Oil Catch Tank with custom paint (black with glitters) $80
- HKS GTRS Turbo $2100
- Hi Octane Racing Pod Enclosure - $100
- Gold Aluminium Air Guide (- $50
- Exedy Twin Plates Clutch (new) - $2000
- NISMO Steel Braided Clutch Hose - $90
DEFI Gauges BF (white lights)
(Frame custom gold)
- Oil Pressure - $180
- Oil Temperature - $180
- Water Temperature - $180
- Boost - $180
DEFI Control Unit (2x) $100 each
($800 for all sensors n 1 control unit)
ARC Airbox (used 1 month) - $390
Down Pipe. $50
Screamer Pipe - $80
SARD Fuel Regulator $80
BLITZ Blow off valve - $50
R2D2 Blow off valve - $50
Custom Oil Catch Tank with custom paint (black with glitters) - $80
HKS GTRS Turbo - $2000
S13 Throttle Body - $80
Custom Intake Plenum (polished chrome) - $120
Advan 17x8(front) , 17x9(rear) - $450
WORK EMOTION CR KAI
17x9.5(front), 17x10(rear) - $1800
Yashio Smoked LED Tail Lights - $600
NISMO Veruspeed Oil Filters:
10pcs available
- $28 per pc
- $25 for 5pcs
WORK EMOTION CR KAI
- $28 per pc
- $25 for 5pcs
10pcs available
- $28 per pc
- $25 for
https://www.sau.com.au/forums/topic/437595-nissan-silvia-s15-jdm-sr20det/
