Hey fellow QLDers
Does anyone know whether you can run private track days at the Norwell track? (Just north of the Gold Coast, for those who don't know of it) I'm looking to get into some more tarmac events this year and since this track is only 15 min from my place, I'd love to get some track time there (even practice days to help sort the car out without the heat of competition).
does anyone know what's involved in running events there? I see that a few clubs have done it in the past (MGCC, Hard Tuned). Would others be keen to do an event if something were organised?
https://www.sau.com.au/forums/topic/437601-norwell-track-days/
Farmer Douchebag and his Son that live behind the Track have complained or complain on a regular basis. Last car to be deemed as too loud was a bog stock SS Commie........
Top Gear even had an event for this year they wanted to put on at Norwell but thanks to the complaints a Highly Popular International TV series was knocked back....all because of noise complaints.
Its a sad case senario.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
