I've rang around a few places to get quotes on the 'major' service with supplied parts and fluids. I've got to admit, most of the quotes have me convinced mechanics are too busy smoking crack with $100 bills and don't want the work. I don't give a stuff what your overheads and problems are. undoing a freaking cover and at worst moving the radiator and unplugable fan does not qualify a grand!
what is it going to take a guy 3/4 hours to pull off the stuff, swap out the bearings (idler), water pump and put on the new timing belt? even at a whole day for one guy with all the parts supplied.
Either way. If you know a guy who can do the work right and doesnt want to charge me a fortune, let me know.
The question is what hourly rate are they charging you ($120 - $140) and how many hours are they allowing for the job?
This can be a pain in the ass job if the pulley on the crankshaft does not come off easy and I have first hand experience with this on my GTR. It can take hours to heat it up and get the seal to crack and let it come off.
The other thing is that none of the remainder of the job is difficult it is just time consuming and you are paying by the hour for the job.
Back in the Skyline heyday the going rate was around $1,500 for labour plus parts from Nissan who were charging $300 per idler bearing - great money if you can get it.
Good luck with your search and it you can get the job done by a shop that you trust for less than $1,000 you will be going well.
With supplied parts and fluids:
CRD (penrith) : $690
JLM (penrith) : $600
(St Marys) Guy who has been reliable and doesnt BS me : (never done this work before) $90 per hour.
Try V sport they were VERY reasonable with my evo.. For $360 fixed price they put royal purple engine oil done the AYC gearbox and diff fluids. Even done extra things like adjusted my handbrake up.. Got the call as soon as the car was done. Very good service indeed.. Dare say was my best experience with mechanics EVER! :D
Changing oil and adjusting the hands brake is substantially easier and could have been done by an apprentice.
The timing belt/idler/pump is at least 4grs work and has the potential to go to shit, hence the amount they charge.
Op, do it yourself. Problem solved.
Yeah no shit mate! What im getting at is their pricing is very good there was near $300 in fluids if I were to roll around on my shed floor and do it myself.. For the extra $60 they can do it and stamp my log book.
Pretty shit advice really Ben making out like its purely a tradesmens job with massive liabilities then telling a bloke who may not have any mechanical skills to do it himself?? ;)
If you ring just about any workshop & say: head gasket, timing belt, clutch, starting $$$ will be around $6-700. All are time consuming & tie up a hoist or work bay for a day or more. For a timing belt on an RB, balancers are on a taper (my RB20 was-modified my puller rather than removing my radiator), then if they find weeping/leaking cam/crank seals, its more time & $$$. If the parts supplied are genuine, most workshops will be more than happy to take on the job. If they are eBay parts, you might pay more in the labour, due to the possible failure factor. I only use genuine parts. I've worked in the industry long enough to respect quality. Aftermarket tend to deviate from OEM design to save money.
I'd be happy to do the job for you at my house, PM me what you want done & when.
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
