Hks Electronic Torque Split Controller (Hks Etc) And Hks Electronic Drag Adaptor (Hks Eda)
Comes with full loom. Plug and play. Used condition.
Pick up in Melbourne or free postage AUS wide - $550 for both
Cheers
Pete
https://www.sau.com.au/forums/topic/437622-gtr-awd-hks-etc-and-hks-eda/
Can they be used on an R33?
To be honest I'm not sure.
These units are identical to the following which state R32 only - http://www.skylinesaustralia.com/forums/topic/425910-brand-new-hks-electronic-torque-split-controller-hks-etc-and-hks-electronic-drag-adaptor-hks-eda/
  • 4 months later...
  • 1 month later...
  • 1 month later...
  • 4 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
