Alrite guys, Kinda new to the forum.
Im located in the US and currently close to finish my rb26 build on my 240sx.
want to see what u guys think and what i might be missing.
Rb26 head:
Supertech vavve guides,springs,retainers
greddy 1.2mm HG and arp head bolts
tomei type b cams
spool oil drain
Stock bore rb26 block
JE 8:3:1 pistons
eagle rods
Arp main studs, acl bearings
collared crank, n1 oil pump with spool gears
9.8qts sump from skyengineering
Raw brokerage twin scroll manigold
precision 6262 bb t4 .84 divided housing
twin tial mv-s
Fuel ID 1000cc injectors
-atm single walbro in tank(enough?)
Haltech plug in
tomei 1.5mm oil restrictor
goal 600hp
What fuel pump you guys recommend?
Max rpm rexommended for this setup?
Also have ross tuff metal jacket damper
Edited by silvianc
https://www.sau.com.au/forums/topic/437626-r32-gtr-600hp-mod-list-complete/
Are we talking 600hp at the motor or at the treads here?
For 600 at the fly then your setup is fine.
600 at the wheels, I think you need a surge tank with maybe 2 walbro's. but it is very dependant on what fuel you will be running to know what your fuel setup should be.
I would've gone with id 2000's
600 hp at the wheel. Using methanol injection. I dont have access to e85 in my area. Was thinking to add a inline pump
I would suggest that on the dyno, your fuel system will probably pass. However if you intend to do any track work, you will need a surge tank. I use a 500lph walbro as a lift pump and a bosch 044 from the surge tank to the engine.
  • 1 year later...
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
