Hi,
  • Just wondering if anyone has fitted intercooler kit like this (non-return) style on a series1 C34 ?
http://www.ebay.com.au/itm/NISSAN-SKYLINE-R32-R33-R34-FRONT-MOUNT-INTERCOOLER-KIT-FMIC-GTST-RB20-RB25-TURBO-/321273282689?pt=AU_Car_Parts_Accessories&hash=item4acd614081
  • Does anyone know of a walkthrough for installing a boost gauge ?
I am guessing it goes through the firewall on the right hand side (looking into the engine bay).
Edited by Direwolf
https://www.sau.com.au/forums/topic/437670-intercooler-and-boost-gauge/
I have, but I don't cut the hole under the battery for obvious (defect) reasons, I run custom piping up beside the radiator.
Hi,
Depends
If it has an electronic sensor the cable can go through with the rest of the loom just behind the inner RH guard.
There is a grommet on the drivers side that you can pull a cable/vaccum hose through. Just get under the dash with a torch and you will see it. You can poke a coathanger (with hose and cable taped to it) through the grommet and grab it from the engine bay/guard side.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
