Happy new year everyone! I haven't forgotten about you, just been busy with the restaurant, especially over New Years!
A few of you have been asking me, so here it is, the first cruise for 2014!
When - 2nd February, 2014
Time - 9:00am at the 1st meeting point (leaving 9:30am sharp)
1st meeting point - Brays Bay Reserve, Rhodes (Oliveto Restaurant car park: cnr Mary Street and Concord Road)
2nd meeting point - Krispy Kreme Car park, Liverpool
Leaving KK's Liverpool at 10:30am sharp!
Destination - Bowral (having lunch altogether)
Look forward to seeing everyone again. Should be an awesome drive, just us and the highway!
Speak soon
Edit: Please note the change of date of this event.
Edited by GoldZilla
Date changed so as not to clash with SAU-NSW Tech Afternoon
https://www.sau.com.au/forums/topic/437689-4-sydney-skyline-cruise-bowral/
Sounds like an epic day. I'll say yes for the moment but it may change as I might be starting a new job so I may have to pull out late.
Hopefully I'll be there though, and probably pretty tired again from work haha
I'm in, well for as much as I can do before the tech night.
Is there anyone else attending this and the tech night? We could make another cruise up to botany
I am thinking of attending both, but not too sure if I can make it in time.
Any suggestions mate?
It's a cafe near the pie shop on the main road. You won't miss it seeing the skylines :)
Good luck getting safe parking at Bowral around the main streets at lunch time on a weekend, You may want to arrange a meet point in Bowral for parking up a back street. Elderly drivers in this area have great touch parking skills :)
Just a suggestion could look at this place in East Bowral http://www.scottisharms.com.au/ has a good beer garden and good food :) has 2 off street car parks also.
  • Like 1
Big call but any chance of changing to an earlier date?
25/1?
Think that is the Australia Day Weekend double points time. If it was on the Sunday the 2nd Feb would get more of the SAU guys that are tied up with the tech day.
Of the shopping centre. But well see on the day :) can't do earlier because of Australia Day.
No probs Terry. I'll make sure cruise number 5 doesn't coincide with any tech nights. That way we can all be together :)
Btw, cruise number 5 is An awesome surprise. I guarantee you will all like it :)
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
