Thanks for a great day out. The station wagon didn't do too bad keeping up with you guys. Look forward to the next one.
Pleased to meet you too Pete.
The reason why you can see all of an EVO in the rear vision mirror is because an EVO can fit into a Stagea cargo bay :P
Look forward to you becoming a Member of SAU! :yes:
  • Like 1
What a day! Had a great time meeting new people and learning about their cars.
Roads, scenery, lunch was all top notch. I bet the little one in the back of the R35 had a blast going up those windy roads :)
Thanks James for cruise 4. Looking forward to #5!
Great turn out, Great weather and Great food... Can't wait for the next one...
Some shots I got today,
http://s1021.photobucket.com/user/ctwoez/library/SAU%20Bowral%20Cruise%20-%20Four
Wow awesome shots buddy! Do you have a facebook page for photography? Would love to share these on my fb
Cheers mate, nah I don't but I'm going to be making a page soon... I'll let you know when I do
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
