Some of you might remember I had those deflectors re made for people using the std cooler and intake. About a week later I installed a front mount and pod and that was fine in winter. Now that it's coming into summer I needed to find a way to keep intake temps cooler. So I've come up with this airbox, I like this one better than any other one I've seen (I'm not biased at all) I'll be using the hole left over from the cooler return under the box to run some pipe to the lhs front grill for cold air.
Would anyone else be interested in one?
And what should I change to make it better/looks nicer?
Also is cardboard flammable? I might use alloy like the deflectors
https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/
Yes cardboard is flammable.
Aluminium would be fine. Some people use Perspex which you can bend with a heat gun.
Or you could use one of your deflectors with the stock airbox and maybe run some extra air into the airbox from behind the headlight.
Lol thanks bob. I'm really keen to get some alloy and cut one out
Something like this? It's going to cost too much to get one made I think.
Yep you can get quite thin aluminium which is easy to bend and cut with some tinsnips or a nibbler if you have or can borrow one.
I was kidding about the cardboard part guys haha
I'm going to use 0.8 like the deflector. No way would I use tin snips, I was thinking maybe a jigsaw with fine teeth or a dremel or a die grinder?
A while since I did some metalwork but I think for soft metals such as aluminium you need coarse not fine teeth. This is a nibbler - they are quite expensive or you can (like I did) get a cheap attachment that goes in an electric drill from a store such as Bunnings:
http://www.makita.co.nz/products/detail.lsd?item=JN1601&-session=Makita:7694CC8C02dc220C0EsKHxACAECB
That looks pretty good! Thanks bob!
I made these a while ago and I'm just throwing up pics now because I'll get it done soon. Here was another intake I made, but they're going to be way too much effort for my skill level
You've done all the hard work. Just flatten out the cardboard and draw around it ...cut out the shapes and then bend!
I'm not too sure yet glyn. I was thinking about that last night,
It really depends on what people think they're worth, as it really is just a top and side piece that is put together by 3 small L brackets, and it is not fully enclosed (it looks it, and almost is). I will still like the look of this better than any other one Iv'e seen for sale.
I'm guessing anywhere from $80? It will take around 2 hours to make, and the cost of picking up the goods and the goods themselves. But I personally don't think too many people will buy one, if someone wants one i will make it.
I've just found some rubber edging. and the exact same bolts that are used on the deflector, so it will tie in perfectly. :)
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
