Trex Posted January 16, 2014 Share Posted January 16, 2014 Some of you might remember I had those deflectors re made for people using the std cooler and intake. About a week later I installed a front mount and pod and that was fine in winter. Now that it's coming into summer I needed to find a way to keep intake temps cooler. So I've come up with this airbox, I like this one better than any other one I've seen (I'm not biased at all) I'll be using the hole left over from the cooler return under the box to run some pipe to the lhs front grill for cold air. Would anyone else be interested in one? And what should I change to make it better/looks nicer? Also is cardboard flammable? I might use alloy like the deflectors Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/ Share on other sites More sharing options...
KiwiRS4T Posted January 16, 2014 Share Posted January 16, 2014 Yes cardboard is flammable. Aluminium would be fine. Some people use Perspex which you can bend with a heat gun. Or you could use one of your deflectors with the stock airbox and maybe run some extra air into the airbox from behind the headlight. Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7171726 Share on other sites More sharing options...
Trex Posted January 16, 2014 Author Share Posted January 16, 2014 Lol thanks bob. I'm really keen to get some alloy and cut one out Something like this? It's going to cost too much to get one made I think. Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7171735 Share on other sites More sharing options...
KiwiRS4T Posted January 16, 2014 Share Posted January 16, 2014 Lol thanks bob. I'm really keen to get some alloy and cut one out Something like this? It's going to cost too much to get one made I think. Yep you can get quite thin aluminium which is easy to bend and cut with some tinsnips or a nibbler if you have or can borrow one. Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7171954 Share on other sites More sharing options...
wolverine Posted January 16, 2014 Share Posted January 16, 2014 0.6mm ally will fold quite easily. 1.0mm will challenge you a bit if you are using basic hands tools... Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172074 Share on other sites More sharing options...
ECR33_RB25DET Posted January 16, 2014 Share Posted January 16, 2014 I had one in my R33 however made it out of stainless steel and powder coated jet black. Worked an absolute treat. Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172108 Share on other sites More sharing options...
Trex Posted January 16, 2014 Author Share Posted January 16, 2014 I was kidding about the cardboard part guys haha I'm going to use 0.8 like the deflector. No way would I use tin snips, I was thinking maybe a jigsaw with fine teeth or a dremel or a die grinder? Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172146 Share on other sites More sharing options...
GH05T Posted January 16, 2014 Share Posted January 16, 2014 im keen, i need something like this for my c34 Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172208 Share on other sites More sharing options...
wolverine Posted January 17, 2014 Share Posted January 17, 2014 fine tooth jigsaw works ok Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172349 Share on other sites More sharing options...
KiwiRS4T Posted January 17, 2014 Share Posted January 17, 2014 I was kidding about the cardboard part guys haha I'm going to use 0.8 like the deflector. No way would I use tin snips, I was thinking maybe a jigsaw with fine teeth or a dremel or a die grinder? A while since I did some metalwork but I think for soft metals such as aluminium you need coarse not fine teeth. This is a nibbler - they are quite expensive or you can (like I did) get a cheap attachment that goes in an electric drill from a store such as Bunnings: http://www.makita.co.nz/products/detail.lsd?item=JN1601&-session=Makita:7694CC8C02dc220C0EsKHxACAECB Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172354 Share on other sites More sharing options...
Trex Posted January 17, 2014 Author Share Posted January 17, 2014 That looks pretty good! Thanks bob! I made these a while ago and I'm just throwing up pics now because I'll get it done soon. Here was another intake I made, but they're going to be way too much effort for my skill level Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172404 Share on other sites More sharing options...
KiwiRS4T Posted January 17, 2014 Share Posted January 17, 2014 That looks pretty good! Thanks bob! I made these a while ago and I'm just throwing up pics now because I'll get it done soon. Here was another intake I made, but they're going to be way too much effort for my skill level You've done all the hard work. Just flatten out the cardboard and draw around it ...cut out the shapes and then bend! Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172780 Share on other sites More sharing options...
Trex Posted January 17, 2014 Author Share Posted January 17, 2014 I bought a heli guy nibbler off eBay. I saw a youtube vid of one and was amazed at how clean and easy the cuts were! Thanks again bob Ok haha I'll try and make the intake part, I really don't have that kind of skill though. Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172788 Share on other sites More sharing options...
Dream15 Posted January 17, 2014 Share Posted January 17, 2014 A while since I did some metalwork but I think for soft metals such as aluminium you need coarse not fine teeth. <br /><br />Lol must have been quite a while ago. You need a fine tooth blade for metal work Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7172803 Share on other sites More sharing options...
GH05T Posted January 18, 2014 Share Posted January 18, 2014 what sort of cost do you think these would be from you bud? Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7173157 Share on other sites More sharing options...
Trex Posted January 18, 2014 Author Share Posted January 18, 2014 I'm not too sure yet glyn. I was thinking about that last night, It really depends on what people think they're worth, as it really is just a top and side piece that is put together by 3 small L brackets, and it is not fully enclosed (it looks it, and almost is). I will still like the look of this better than any other one Iv'e seen for sale. I'm guessing anywhere from $80? It will take around 2 hours to make, and the cost of picking up the goods and the goods themselves. But I personally don't think too many people will buy one, if someone wants one i will make it. I've just found some rubber edging. and the exact same bolts that are used on the deflector, so it will tie in perfectly. Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7173258 Share on other sites More sharing options...
Jnr Posted January 18, 2014 Share Posted January 18, 2014 id be keen on one Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7173625 Share on other sites More sharing options...
Josh080691 Posted January 18, 2014 Share Posted January 18, 2014 I'll take one too Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7173629 Share on other sites More sharing options...
stock stagea Posted January 19, 2014 Share Posted January 19, 2014 You know that I want one Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7174271 Share on other sites More sharing options...
GH05T Posted January 19, 2014 Share Posted January 19, 2014 it wont need to be fully enclosed, just keep the heat away and help use the cold outside air. Link to comment https://www.sau.com.au/forums/topic/437690-alloy-airbox-eoi/#findComment-7174430 Share on other sites More sharing options...
