Time to jump into a R33 S2/S14A so my R32 has to go, negotiable on price, will consider all swaps, but more after a R33/S14...
Located in South-West Sydney, have dyno print-out and time slip and some receipts for work carried out.
1993 R32 GTST
RB20DET
12X,XXX
March 2014 Rego
TD05-18G
Turbosmart 40mm Ext Gate
Custom V-Band Dump
High- Flow Cat
3.5" Greddy Cat-Back
550cc Nismo Injectors
Walbro 255 Fuel Pump
Nistune (JEM 238rwkw @ 21psi)
JJR Front Mount Kit
Custom Cold Air Intake
Z32 AFM
-10 PCV Set-Up
Plenty Of Engine Bay Parts "Wrinkle Coated"
Yellowspeed Coilovers
Cusco Front & Rear Strut Braces
Adj Front Toe Rods
Nismo Rear Upper & Lower Control Arms
Z32 300zx Rims 16x8"
Kaaz 2-Way LSD
AEM Wideband
Defi 1-Din
Turbosmart Eboost 2
Turbo Timer
Pioneer CD Player
32GTR Front & Rear Seats
GTR Bonnet
GTR Grille
Carbon Bonnet Lip
LED Taillights
Genuine Floor Mats
Bad Points
* guards have been back yard rolled
* smallest amount of rust on top of front windscreen on the drivers side
* paint needs a general buff/polish
* front bar is rattle canned (originally black)
* second gear synchro shot, crunches on quick shifts from first to second, and third back to second.
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
